Old February 13th, 2019, 14:17   #16
highmileage
*your*
highmileage is offline   Reply With Quote
Old February 17th, 2019, 08:36   #17
wtribeflyer
Fuel Economy: Yes
Originally Posted by afarfalla View Post
the seat belt has a built in stick of dynamite that explodes and locks the seat belt, tight, in a crash, they never retract once the explosion occurs. One time use.
My seat belt retractror exploded in a frontal crash before I bought my b5.5 but the seat belt still retracted fine it just sets an airbag code.. IIRC.
wtribeflyer is offline   Reply With Quote
Old February 28th, 2019, 04:33   #18
highmileage
Just to follow up and state what I did. May be helpful to somebody. I bought a used clockspring on E-bay. Installed replacement part. DTC's changed. ABS module now needed to be recoded and steering recalibrated. This was done with VCDS. All good.
Old February 28th, 2019, 10:00   #19
zzdiesel
I am at this point also. How did you recode and re-calibrate this?
zzdiesel is offline   Reply With Quote
Old February 28th, 2019, 18:50   #20
highmileage
Default coding
It is a relatively simple process using Ross-Tech VCDS. There is a video on youtube demonstrating the process. Search youtube for "coding the Bosch 5.3 and 5.7 ABS modules." The video I used was 10 minutes and 17 seconds long to help identify it. It is helpful. You need the brake production code and some other basic information to figure out your login code and recoding code. There are some others, such as calibration 40168, others given in the video. Procedure is to get abs module number, figure out the login number. My car was 09557 for the login number. BHW cars are likely similar with the exception of the third digit which could vary depending on brake production code. Video of A4 was 1LE, as was mine. You then get the soft coding number similar process to login. Mine was 04257. Brake pr code variable also. There are possible workshop and importer codes on the soft coding page, Then you recalibrate.(40168) The dtc's I had were 00778-steering angle sensor-not matched-intermittant and 01044-module incorrectly coded. Erased by procedure. Any further questions feel free to ask and definitely watch the video. It goes step by step. I think it is a good idea to write down all your numbers before you change anything so you can always go back. if necessary. Good luck.
Old March 1st, 2019, 09:50   #21
zzdiesel
Thanks, I think I will need it.
Old March 1st, 2019, 10:21   #22
highmileage
Don't be concerned. Just go step by step. It really is easy. What I did was play/pause the Ross-Tech video as I was doing the procedure. I also watched the video a couple of times first to get a better grasp before I started.
Steering Angle sensor help... VincenzaV VW MKIV-A4 TDIs (VE and PD) 49 April 9th, 2018 03:34
Steering Wheel Not Centered - Steering Angle Sensor - Ross Tech Adjustment gmcjetpilot VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 8 May 24th, 2015 06:26
Steering angle sensor where to but Bmoon1102 VW B5 Passat TDIs 0 July 25th, 2014 20:54
Steering Angle Sensor mogly VW B5 Passat TDIs 5 September 26th, 2013 07:24
steering angle sensor steved2121 TDI 101 4 August 30th, 2007 21:17
Page generated in 0.15815 seconds with 13 queries
[Output: 79.87 Kb. compressed to 69.76 Kb. by saving 10.11 Kb. (12.66%)]
