Old February 10th, 2019, 11:59   #61
Rub87
Originally Posted by WarmStart View Post
P-pump uses notched plungers to advance timing. At full rack travel notches will close suction ports earlier.
There are some small factories who can make you small batch off nozzles what ever you need. But much cheaper is extrude honing your nozzles.
ok but that doesnt really count as you timing in funtion of rpm, not really in function of load..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
camplate dti-vs tdi mk1-83 TDI Power Enhancements 16 October 17th, 2016 07:49
11mm camplate in 10mm pump HO'OLAKO TDI Power Enhancements 77 October 22nd, 2012 13:21
11mm pump camplate papi123 TDI Power Enhancements 1 December 30th, 2010 01:26
WTB DE143 11mm camplate HO'OLAKO Private TDI Items for Sale/Wanted 7 June 11th, 2010 09:01
Larger IP camplate? visionlogic TDI Power Enhancements 4 September 6th, 2007 12:54
Page generated in 0.09954 seconds with 13 queries
[Output: 49.98 Kb. compressed to 47.14 Kb. by saving 2.83 Kb. (5.67%)]
