Hi guys I have an issue with my 2012 VW Passat SE tdi I have the P0771 code being displayed in VCDS. Anybody seen this issue and were you able to repair without a new valve body? Any luck finding the (N92) shift solenoid? May also have a leak in the transmission I see fluid leakage around the Auto Trans Cover and on the splash shield.
I was driving my car and a the car dropped out of gear like it was in neutral with a flashing wrench. I shut off the car and restarted the car and car drove fine for about 10 days and then it happened again.
1 Fault Found:
17155 - Shift solenoid 5 (N92)
P0771 - 000 - Open or short to Ground - Intermittent - MIL ON
1 Fault Found:
