cada
2012 Passat TDI with 97.5K (60.5 mi). Purchased used in October 2015 with 72K (44.7 mi).
I was having an intermittent ticking sound when I released the clutch. Sometimes it would last the whole drive to/from work, other times I could only get it to happen with the clutch 90% out, other times I couldn't reproduce it at all. Brought it to a local dealership for a recall (unrelated), so I had them check it out.
Here is what the technician recorded on the work order as the cause of failure.
“VERIFIED COMPLAINT. NOISE PINPOINT TEST REVEALED TICKING NOISE COMING FROM TRANSMISSION HOUSING ASSEMBLY. REMOVED TRANSMISSION TO FURTHER INSPECT. FOUND BROKEN PRESSURE PLATE RETAINING SPRING AND SHEARING THE INSIDE HOUSING OF THE TRANSMISSION CASING. WILL REQUIRE TRANSMISSION REPLACEMENT, CLUTCH / PRESSURE PLATE ASSEMBLY AND FLYWHEEL REPLACEMENT”
The kicker? VW claims that it's not covered under the 5 year /100km powertrain warranty, because it's a "non-lubricating" part. (They said it would have been covered under the 4 year / 80km warranty). To make things worse, the 3rd party warranty I purchased says they won't cover it either, for the same reason.
Does this make sense? Does this sound reasonable?
Thanks!
Chris
Thanks!
Chris
