mrmoto35
Update: While I wait for the "Fix" and my money from VW I am in the process of hardening the transmission for 235-240hp/470lbs torque we plan to achieve. I would love to go much higher but not in a FWD car.
1) New Flywheel & Bolts
2) New WaveTrac Limited Slip diff w/case clearance
3) Cadillac STS Trans Fluid Cooler
4) Thermostatic Switch, High Volume Oil Pump, An8 Fittings and Lines, and an aftermarket steel oil pan with AN fittings (works in conjunction with the OEM cooler)
5) New Clutch Pack, Bearins, Seals etc
6)Torco High Temp DSG fluid
