ss2nv
OSRAM 65w Rallye AND Upping Voltage with VCDS?
Hello. We just purchased a 2014 Passat SEL TDI and I am unhappy with the factory headlight output. I have read around and have decided to install the OSRAM 65 watt Rallyes. I have seen where others have done this and been happy, but what about also upping the voltage with VCDS? The OSRAM bulbs say that they are rated for 12 volts on the box. I just purchased the Micro-CAN cable from Ross-Tech and was wondering how high I could go with the voltage, or even disable the bulb-saver feature alltogether? Any thoughts?
Thanks.
Seth
Thanks.
Seth
