flargabarg
- Joined
- Jul 31, 2005
- TDI
- 2011 Touareg Lux TDI
But why do that? The engine is likely delivering a higher BSFC than it would be at slightly higher revs for the same load.
Find a torque vs. RPM curve that has constant BSFC curves mapped on it. Running at the highest gear at the lowest RPM will put your operation in the lowest fuel consumption. This is true generally on any engine, though I'm sure there are specific cases where this is not so.But why do that? The engine is likely delivering a higher BSFC than it would be at slightly higher revs for the same load.
How many diesel engines have you seen destroyed from this type of operation?Different strokes for different folks I guess. I remember my dad telling me as a kid that the worst thing I could do when operating the diesel tractors (other than flip them over) was to lug them way down in the powerband.
You really don't have a choice. At highway speeds, you're going to be running at least 1800 rpm (on a 2-liter), unless the 6MT is geared significantly taller than the DSG.I pretty much guarantee you'll never hear any tdi guru recommend cruising around at <1500 rpm in high gear.
I feel bad for your turboWhy would the manufacturer of the engines, who have the ability to tailor rail pressure put out by the pump, allow the pump to supply rail pressure in any zone of the operation of the engine to cause the engine to become damaged by operation in this range?
-- Nicole
Really? I thought it was worse for a diesel to lug that to wind.Find a torque vs. RPM curve that has constant BSFC curves mapped on it. Running at the highest gear at the lowest RPM will put your operation in the lowest fuel consumption. This is true generally on any engine, though I'm sure there are specific cases where this is not so.
Typically, it's thought that 800 - 1000 feet-per-minute average piston velocity will give you the best fuel efficiency. Though that's a highly generalized statement, it's fairly universal.
This will also greatly extend the life of engine components.
-- Nicole
On the '10-'14 2L tdi's the 6mt is geared much taller than the dsg. From what I've seen the '15 dsg is actually geared taller than the mt. In any case, it sounds like some folks here are using 6th gear at much less than highway speeds.You really don't have a choice. At highway speeds, you're going to be running at least 1800 rpm (on a 2-liter), unless the 6MT is geared significantly taller than the DSG.
Most people who tell you it's bad for an engine to run in a high gear at low RPMs say so due to the detrimental effects this has on a gasoline engine. This is the ideal condition of operation for a diesel engine and where a diesel engine proves a difference from gasoline engines.Really? I thought it was worse for a diesel to lug that to wind.
EDIT: Just read the rest of the posts. Maybe i was told wrong?
Diesels prove themselves under heavy load at low RPMs. If it's ok to run in that condition for a short while (and by definition it is ok if the programming allows it), it's ok to run in that condition perpetually. Even though the 2.0L TDI is a high-revving diesel engine, it still has a strong diesel bottom end. You can't drive it like it's a 6.7 L CTD, but it definitely operates like a diesel nonetheless.I think the heavy load coupled with low rpm can be detrimental for the engine if driven too long without downshifting. However, I agree that on a relatively flat road practice of driving with highest gear and the lowest possible rpm would produce the highest FE.
That BSFC map clearly shows the engine is most efficient at nearly full load between 2000-3000 rpm.
+1Diesels prove themselves under heavy load at low RPMs. If it's ok to run in that condition for a short while (and by definition it is ok if the programming allows it), it's ok to run in that condition perpetually. Even though the 2.0L TDI is a high-revving diesel engine, it still has a strong diesel bottom end. You can't drive it like it's a 6.7 L CTD, but it definitely operates like a diesel nonetheless.
-- Nicole
I'm going to go with the highest gear possible at any speed will result in the best cruising mpg.
1500 rpm in a diesel is just fine.
I had my TSI at 1500 rpm, top gear, going up an incline at 45mph with 3 adults in it. Never lugged, car never told me to downshift.
The DSGs will hit 5th at 35mph in town! No worries.
But we're not talking about full load, we're talking about light load.That BSFC map clearly shows the engine is most efficient at nearly full load between 2000-3000 rpm.
Fair enough. The map shows the worst efficiency is at the lightest loads. People can drive their cars however they like. I won't be lugging mine.But we're not talking about full load, we're talking about light load.
So, if you're running 3000 RPM and the torque is at the 6 line, you're practically at the 230 BSFC line...which corresponds to practically 210 BSFC line at 1500 RPM, since you'd be at the 12 line on the torque axis.Fair enough. The map shows the worst efficiency is at the lightest loads. People can drive their cars however they like. I won't be lugging mine.
No, that's not the opposite of what I'm saying. I for one don't run around at 3000 rpm under extremely light load. And I'm reading much closer to 219 g/kw hr for 1500 rpm at 12 bar mean effective pressure. That example corresponds to 40 hp. At 40 hp that engine is more efficient at 1800 rpm than 1400 rpm. Even if dogging around at <1500 rpm did save a penny or two, it's not worth the abuse the engine and turbo would take. And most importantly to me, I don't like sluggish throttle response.So, if you're running 3000 RPM and the torque is at the 6 line, you're practically at the 230 BSFC line...which corresponds to practically 210 BSFC line at 1500 RPM, since you'd be at the 12 line on the torque axis.
That's pretty much the opposite of what you're saying.
-- Nicole
I have no idea if lugging would result in more soot, but my feeling is it would. But we are not talking about lugging here. Running these cars at steady speed around 1500 RPMs is not lugging. If you are towing a trailer and going up a big hill at 1500 RPMs, then you are lugging!Also, does the lugging = more soot? Maybe not the same as jamming down the throttle at low rpms but more soot than the 1800 to 2200 range?
