Now It's popped up a different issue. It's not getting full boost anymore, it drives not in limp mode but with low power. I could probably drive it like this, but I couldn't tow it for sure.
Codes
I got the EGR code 16786 for excessive flow and MAF G70 implausible signal. EGR code never came back after clearing it, but the MAF did a couple times.
Took the MAF's off and there was a good amount of dust. I sprayed it but it didn't seem to help so I bought a new Bosch Unit for the engine 1 (right bank).
Logs
-Here are some logs. I'm really rusty on MAF troubleshooting but after reading MAF 101 (10 years later), if the vehicle runs better with the MAF unplugged, that points to a dead or dieing MAF. But I just replaced it. code it showing engine 1. Do you think the engine 2 could be the issue but the other MAF is what throws the code and underperforms?
Boost
Boost log during the MAF runs was showing lack of boost on engine 1. During basic settings output test, for some reason, now engine 2 is underperforming and engine 1 is now performing well.
I need to fix the tiptronic strip, so I couldn't hold it in gear very long.
MAF isn't throwing a code with this logging. Any ideas? (during this run). turbo actuator hasn't thrown its code since the last "fix"
N18 are new, MAP sensors are new, and now MAF on bank 1 is new.
MAF logging with new Bosch unit installed.
MAF unplugged
MAF unplugged boost log (I should have done a run with the MAF in too)
