Crazy, funny or infuriating? (VW not you) What the h*ll is G-060-726-A2? Are you sure he did not say G-052-726-A2? G-052-726-A2 is a super thin fluid. Below is my post submitted to the other relevant threads. Read the part about what dealers say.JoeGreen said:So.. I read all 25 pages.. figured I’d go with whatever VW recommended for my 1996 B4 Passat.. The parts guy said that “the internet” says I need G-060-726-A2 @$14.75 per “Quart” . He also said it was Synthetic.
I can find nothing in this thread with that number?
Can I believe them?
What is a spyder gear and a what does a spyder gear noise sound like?StevenM said:Some newer cars developed a spider gear noise with G50 and thus VW issued a TSB saying to change to thin stuff, old cars need not be concerned..
For the automatic use only the VW fluid! AlanTDI in Merrick had problems with another fluid that the rebuilder used. I am in Queens,btw.TDI1220 said:03 tdi automatic tranny, what fluid should i use? Also
what oil is recomended 1.9
I wouldn't mind actually talkin to someone about the work i wanna do on my vw. Anyone from New York? pref Long island. Anyone goin to Waterfest? I'll be there
I'd like to know this as well, I didn't see anything for AHU......JoeGreen said:So.. I read all 25 pages.. figured I’d go with whatever VW recommended for my 1996 B4 Passat.. The parts guy said that “the internet” says I need G-060-726-A2 @$14.75 per “Quart” . He also said it was Synthetic.
Can I believe them?
If you do this, please let us (or me!) know!Shenandoah said:I might send it in for oil analysis to see what viscosity it had and try to order the closest one on Andy's chart.
This is what I like to hear. I have been preaching this for a long time.DieselDrink said:Wow this is a long thread. I've tried to extract the right info here, but FYI-
I quickly changed it back out to the G-052-171-A2 synthetic which is for 6spd but I was told backward compatible to the mineral version listed in my Bently.
It is like butter! In the cold weather also. I'll leave that in there now. Great stuff.
Mobil said not to use a GL-4 or GL-5 fluid?ngdkuem73 said:This is what I like to hear. I have been preaching this for a long time.
I had a bad experience with Mobil1 and when I talked to them they said do not use it in my '00 VW 5 speed
SUNRG said:If your transmission specifies G52 fluid I highly recommend sticking with it as opposed to changing it out for one of the popular/common replacement manual transmission fluids because the viscosity of G52 is much thinner:Viscosity Comparison @ 100 C
With just over 43,000 miles on my 2004 Golf TDI 5-speed I drained my manual transmission fluid, re-filled with Motul Gear 300, and I brought samples of both the used G52 and new Motul Gear 300 to my local CAT fluid analysis lab.10.6 = Redline MTL 70-80
13.8 = Amsoil MTG 75-90
15.2 = Motul Gear 300 75-90
15.6 = Redline MT-90 75-90
15.0 = Elf Tranself Synthese FE 75-90
16.7 = Motul MOTYLGEAR 75-90
6.3 = OEM G52 (part numbers G052726A2 / G05272601)
Since I had written on the G52 oil sample label 75w-90 the lab viscosity tested the sample twice - both times returning a V@100c of 6.4.
My thinking was that either the OEM oil sheared way down OR the OEM fluid started out much lighter than the expected 75w-90.
So, I went to my local dealer this morning, bought a liter of G52, then drove to my local CAT fluid analysis lab and watched as he tested its viscosity right in front of me.
The result: VOA viscosity of G52 = 6.3
OEM G52 did not shear down at all in 43,000 miles of use:V@100c: New G52=6.3, G52 after 43,000 miles = 6.4Additionally, in these crazy unseasonably warm temps the Motul Gear 300 shifts fine - but early yesterday morning when temps were in the mid 40s - the first few shifts with Motul Gear 300 were noticably more effortful than the G52 ever was - even at below 0 temps.
Point being that even though Motul Gear 300 has an outstandingly low pour point (flows to -60) - **the 75-90 viscosity of common gear / manual transmission oils is IMO not suitable for use in VW transmissions where G52 is specified.**
OEM G52: 43k UOA
Motul Gear 300: VOA (this is as expected from a 75w-90 oil)
OEM G52: 43k UOA
