I'm in the UK and have a 2005 Mk5 Golf GT TDI 140 with a 6 speed gearbox.
My gear changes are stiff from cold and alsoI have a slight crunch/grind going from 1st to 2nd gear only from cold if I shift too quickly. Once warmed up it's beautiful no problem at all.
It's on 101k miles and only recently put the G052 gearbox oil in. I had hoped it would make a difference but it hasn't really.
I'm currently trying to figure out if using either a thicker or thinner gear oil would be beneficial.
I can see a thicker oil would slow down a gear change giving the syncros more time to engage and maybe give the syncros/cones a thicker coating of oil to grip with?
A thinner oil I can see would perhaps clear quicker as the syncro slides over the cone giving more metal to metal contact which may grip better?
Currently confused, thicker or thinner for a slight 1st to 2nd crunch when cold?
I wonder if using G060 or G070 might be better? Are they thinner oils?
Hope you can advise me folks! Thx!
