Okay, this car has a lot of miles and needs some work. It starts and runs and stops, and has done so through several Wisconsin winters. Here's the deal:
- 294,000 miles.
- It leaks engine oil. About a quart every 1000 miles. I'm not sure where the leak is coming from.
- I've hit several deer with it. The grill is broken and the hood and fenders are dented. The hood opens and closes fine with a little care.
- The tires are pretty much worn out.
- It needs suspension work, most notably rear axle bushings.
- The drivers window and both rear windows do not go down.
- The passenger's window and the moonroof DO work.
- Timing belt was replaced about 11,000 miles ago.
- Clutch still seems fine, transmission too.
- AC does not work, condenser was damaged by the deer.
- Still gets 45+ mpg.
This has been a very dependable car for me, but it needs work now and I don't feel like putting the effort into it. The car is located in Madison, WI at my workplace, so is available to be looked at (or bought!) every weekday 7-5.
I'm asking $1200.
Email me at aaronawolfe@gmail.com with any questions.
Pictures here: http://picasaweb.google.com/aaronawolfe/1998VWJettaTDI?feat=directlink
- 294,000 miles.
I'm asking $1200.
