TooMuchBoost said:
This was your next mistake after you decided not to hold the dealer accountable. Your insurance company just wrote you an estimate for your vehicle to be fixed by their contracted hail damage guy based on a discounted labor rate and a discounted book hour rate . This is called steering.
State law should require only one legitimate estimate and 9 out of 10 times an insurance company provided estimate is very low. Why? Because 50% of all insurance claims for auto body work are never repaired...but the check is cashed. If they low ball you and you spend the check on a vacation instead of getting the auto repaired you'll never know you were screwed. If they write an estimate and cut a low-ball check but you take the vehicle to a legit body shop preferably one that isn't an Allstate recommended program shop that shop writes a real estimate at a real labor rate with real book hours. He then calls Allstate for a supplement estimate and another check to cover the difference between the low-ball estimate and the legit estimate.
You need to find a legit higher end shop that is capable of quality all over paint jobs (just in case) and have that guy write you an estimate to repair or replace panels and an all over paint job. Ask him if PDR work is even feasible on your car and if so who would he recommend for an estimate. Nothing says you can't have a legit shop write a legit estimate for $5K, get a check then have $3K of PDR work done either.
Here's another problem...if your car is fubar'd on every panel and needs holes drilled every where to get PDR tool access (how else do you think they do it if they can't get behind it?) or ir needs an body work and all over paint job it will no longer be worth what a car that has never had body/paint work performed. This is called diminished value and it will smack you between the eyes when whoever you try to sell or trade the car to down the road because the odds an allover paint job or million PDR pricks and prods won't be obvious are pretty slim.
FWIW- Never ever take a car to an insurance recommended shop that you don't know personally. That BS warranty they sway you with doesn't transfer when you sell the car and when the average consumer keeps a car a total of 3 years they know its practically worthless other than for bait.
When this is over call State Farm as Allstate ranks right there with Progressive as one of the worst big name insurers for a body shop to deal with.
The Check is made out to me and I can take the car to any shop that I want. If the shop says that it is more then they just call Allstate and Allstate pays the additional. I have been throught this before and they do pay. The car was written up as PDR but if there is a problem with it then they pay what it taked to get the car fixed.
As I was told by the adjuster, all shops do the PDR or are in bed with someone that does. So I can take it where ever I want. They are not allowed to give a list of shops but they can suggest some. I have a shop that I know does excellent work and has done it many times for me.
They do not drill holes. They remove things like headlights and moon roofs to gain access to the areas that are damaged. For the areas that can not be accessed, they glue on to the panel and pull it up.
The insurance adjuster said that the only place he was concerned about was the rail running above the doors because they cannot get behind that real easy. So he said if that needs to be done another way then the body shop just needs to call in and Allstate will give them the additional to fix it.
While I was at the dealer they had their PDR guy there fixing their cars and he looked at mine. He said no problem but he will have to glue on to the ones on the rail above the door. By the way, he was there fixing 137 cars that the dealer had hail damaged in the same storm. This includes an Audi A4 which has an aluminum body and he fixed that perfect.
I'm sure that the people in Louisiana and Florida would not agree about the State Farm statement.
Holding the dealer responsible was not an option. Even my insurance company said that they really are not at fault because it was an "act of God". In an instance like this they would not even go back after the dealer to recoup their money. I could argue until I am blue in the face or take them to court. But when my own insurance company says it's not the dealerships fault then it's going to be pretty hard to get a judgement in my favor. So I did get my car covered by insurance and I did get the whole deductable from the dealer. So I don't really see where I made any mistakes.
FWIW - I'm not nearly as dumb as I look.
