I have a Jetta wagon 5speed that i bought off the original owner that ordered it.
he was a very meticulous owner that has a log book with all the maintenance and every fill up and what mpg he achieved on each one. it is a gls completely loaded with steering wheel volume and cruise control sunroof heated side view mirrors heated leather seats. I d have the rear headrests i just don't have them in the pictures and i have the rear cargo cover in tan as well. It also has tow package with trailer light hookups. just rolled 170k miles i bought it with the intentions on amping the performance up a little bit and daily driving it but my commute to work isn't nearly as long as it was so i cat justify keeping it with a 5 miles commute.
Maintenance ill just start at 140k miles he has records from new in the book
new 100k timing belt kit at 100k
142kmiles-fuel filter front brakes and rotors
143k miles 4 new Michelin tires filled with nitrogen
avg mpg 49.5
150k oil change and filter rotella
152k trans oil changed
153k new front rotor under warranty
48mpg avg
159k rear rotors and pads oil and filter rotella
160k new rear brake lines
50mpg avg
4/7/17 165k reverse light switch
replaced temp sensor
48mpg avg
168k Injectors sent out rebuilt with 517 bosio nozzles
right passenger caliper replaced
3/5/18 169k oil filter change filter mann rotella
new fuel filter 49mpg avg
170k New rear main seal
single mass flywheel cut and balanced @auto machine in st.charles il
new SACH power clutch and pressure plate
new TOB new fork and pivot bushing. all new stretch bolts for flywheel and pressure plate.
Karma TDI Q-loader with 2 tunes 1 for eco
and one power tune. I am still currently breaking new clutch in so its set on eco tune currently getting an easy 50mpg.
The car is truly in fantastic condition. It would be hard to find better example of a alh wagon with good miles.
I am asking 7500for the car OBO
if you dont like the price thats fine you don't have to buy it not in a rush to sell it. Car is located in Geneva il 60134
https://imgur.com/a/Pq1xr
avg mpg 49.5
48mpg avg
50mpg avg
48mpg avg
