TheTDIWagonGuy
Registered Vendor , w/Business number
Are you referring to the fuel module or the replacement pump?Is there a step by step somewhere of how to change it out?
I agree. Just be careful that you don't break off one of the plastic fittings protruding from the pump housing, as I did. I must have committed this expensive error while tapping on the frozen rotating ring that hols/seals the pump into the tank. Still not sure how I screwed that up.Just ordered a pump, since I have the old style I rather stick with it in-case the pump fails again at least I won't be stranded.
Do you mean the pump motor or on top of the module?could you tell me what is the actual size of the nipple coming out the pump? it seems that a larger size might be a good fit from the picture... am i wrong?
No problem! Sometimes shipping is super fast and sometimes it's not. Glad your happy.Wow the pump got to my door super fast! Thank you!
I have an old model one (the one I took out when I bought the new pump from you). I could ship it to you for the "how too" instruction creation?So I have not been able to get my hands on an old lift pump to do the "how to" for the replacement motor. When I do I'll post it.
Thanks for the info.A most excellent kit! Includes replacement hose and clamps.
I bought the replacement pump motor for the old style BEW lift pump, tan/beige plastic housing/sender.
http://www.defender-tech.com/product_p/bewlpr.htm
Installed it, in 2004 Golf, with the help of this thread.
http://forums.tdiclub.com/showthread.php?t=225672
Cut a hole in large thick garbage bag slightly larger than pump access hole, surgery style, and duct taped it to hole to protect interior.
Whole job took 2 hours in the heat with a beer and being careful.
Definitely CUT the old hose off the barbs with razor/Xacto blade.
Small flat screwdrivers and various picks are ideal tools for disassembly.
And rags and spraycan solvent/cleaner and catchpan and flashlight.
I just ordered my replacement pump. Great deal!! I'm way too lame to replace just to pump motor so does anybody want to make an offer on my existing lift pump I will be pulling out?
