philngrayce
- Joined
- Oct 18, 2004
- Location
- Connecticut
- TDI
- '02 Jetta, '06 Jetta, Both Gone '13 Leaf, Gone Liberty CRD, Subaru Forrester and MB300SD
2002 Jetta 5 Speed, 185,000 miles. Starts and runs well, but power is way down. Can't maintain speed on the hills and seems to run out of power at around 3,000 rpm in any gear. Also has a pretty significant vibration under heavy throttle between 2,000 and 2,500 rpm.
I just cleaned out the intake manifold (thanks for the info); also replaced a bad MAF about 10,000 miles aago. The intake manifold was pretty gunked up, and cleaning it seems to have improved the power some but definitely has not solved the problem. (I'm really kind of amazed it ran as well as it did with all that restriction.)
The only code I get (with my OBD II scanner, not a vag-com) is P0673 - Glow plug heater cylinder 3. I've been getting this for a few months, and replaced the #2 and #3 plugs, but the code comes back. And it starts fine, so I pretty much ignore it.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
