Was running down the highway at 70 mph and suddenly the "STOP engine" warning came in due to low oil pressure. Turned it off and coasted to roadside. Checked oil level and it was good. No leaks also. Couldn't help myself and restarted it. She started just fine and idled great with no smoke and no oil light. As soon as I applied a little throttle, the oil light came on again, but quickly went back off once she settled back down to an idle. Never did start smoking and temperature gauge never increased beyond normal.
Noticed that engine made a random "popping" sound at idle and increased somewhat in frequency as throttle was applied. Appeared to be coming from turbo/passenger side.
Towed to my regular TDI guru/specialist mechanic who did a quick diagnosis. Said he had never seen or heard a TDI make that noise before. First impression was maybe the oil regulator, if not the balance shaft assembly.
Has 160K miles. Geared balance shaft and t-belt put in at 80K (2009), cam replaced at 100K. 505.01 5W-40 oil and fllter replaced every 10k and just replaced less than 1k ago.
Will post results once problem is determined.
