CTN 02A Manual 5-speed Transmission with 188K miles. All gears work. Syncros are wearing, but not worn out. Also includes flywheel, pressure plate and clutch.
The clutch thickness is 0.300 " +/- 0.005" (7.62 mm +/- .127mm)
This transmission should work in the following A3 and B4 models:
GOLF 96 Manual Transmission; 1.9L (turbo diesel, Canada), trans code CTN
GOLF 97 Manual Transmission; 1.9L (turbo diesel), trans code CTN
GOLF 98 Manual Transmission; 1.9L (turbo diesel), trans code CTN
JETTA 96 Manual Transmission; 1.9L (turbo diesel), trans code CTN
JETTA 97 Manual Transmission; 1.9L (turbo diesel), trans code CTN
JETTA 98 Manual Transmission; 1.9L (turbo diesel)
JETTA 99 Manual Transmission.; VIN H 8th digit, 1.9L (turbo diesel)
PASSAT 95 Manual Transmission; 4 cyl, diesel (trans code CHU & CTN)
PASSAT 96 Manual Transmission; 4 cyl, diesel (trans code CHU & CTN)
PASSAT 97 Manual Transmission; 4 cyl, diesel (trans code CHU & CTN)
Asking $300 unfirm plus shipping from Reno,NV. Prefer pickup, but will ship. Post or PM with any questions.
Cheers,
-illya
Cheers,
-illya
