Old December 2nd, 2018, 16:18   #16
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
your new maf sensor needs to be written in the file to be working.
why do you upgrade it in the first place? you maxed out the original one?
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old December 3rd, 2018, 13:22   #17
Pittdawg
Not sure if it's maxed out but has to be close, I'm pushing slightly more hp than the 313 hp BITDI and I doubt Audi would have enlarged the TDI Maf from 80mm to 88mm if there was no need or benefit to it.
Pittdawg is offline   Reply With Quote
Old December 3rd, 2018, 14:47   #18
eddie_1
eddie_1's Avatar
It mainly helps if you are pushing power beyond 4000rpm. Do you have a dyno/power plot?
If the logging for IQ is setup in the tune, you can see (using vcds) if requested vs actual IQ is being limited. That's when the bigger MAF helps, usually helping at higher rpms.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old December 5th, 2018, 16:26   #19
Pittdawg
I don't as all the dynos nearby are only 2wd! But it certainly seems to fall flat in the higher rpm range.
Old December 6th, 2018, 01:31   #20
altz1
TDI(s): Allroad, A8
Log the MAF output signal under max load and rev range and you will see if it is maxed out.
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old December 11th, 2018, 18:52   #21
Pittdawg
What's the max? I've glanced at it on my torque app but the values don't really mean anything to me.
Old December 12th, 2018, 06:33   #22
hatemi
I have a feeling that you allready have the same MAF as bitdi. At least 2015+ a6 have those. Check what number you have on the semsor body
Lähetetty minun BLA-L29 laitteesta Tapatalkilla
www.tdituning.fi
hatemi is offline   Reply With Quote
Old December 12th, 2018, 22:27   #23
Macradiators.com
The sensor is identical from 2010->
The housing is different code N and Q at the end.
CP3 Upgrade
Old December 13th, 2018, 01:53   #24
hatemi
And new single turbo versions have the larger housing.
www.tdituning.fi
Old December 13th, 2018, 16:49   #25
Pittdawg
Haven't checked yet but I have the CPNB engine code so probably you are right.
Old December 14th, 2018, 03:00   #26
altz1
TDI(s): Allroad, A8
Jep, i think its the S housing, correct?
2.0 TDI BiTurbo 240 ps engine technical details mickyTDI TDI Power Enhancements 10 July 21st, 2016 07:06
TDI Biturbo Edition concept kramdunc TDI News/Tech 0 May 15th, 2015 12:16
Is there an expected date of release for the BiTurbo TDi? Mac26Mac VW Passat Family (NMS and B7) TDIs (2012+) 1 March 12th, 2014 08:52
Audi Cuts A6 Prices Ahead Of 3.0 TDI Biturbo Arrival HeAvYfUeL Other VW Group TD(I)s 0 January 6th, 2013 17:36
biturbo? titantdi TDI Power Enhancements 34 June 9th, 2008 19:58
Page generated in 0.13784 seconds with 12 queries
[Output: 106.12 Kb. compressed to 89.91 Kb. by saving 16.21 Kb. (15.27%)]
