churchwalk
Hello!
Please can anyone advise what next to try to help my overheating golf?
Model:
- 1.9 tdi 2005 pd105 Engine code BKC
Symptoms - When accelerating hard for example from 50mph to 70mph the blowers will go cold, then the coolant temp gauge raises up, sometimes all the way triggering, then if will slowly drop down. \the temp then drops and the blowers go hot.
- Often when the car is stopped the fans are still going for it
- The coolant is sometimes spurts out of the heater tank overflow - due to over pressure?
- no fault codes
What I have tried:
- replaced header tank and cap
- replaced thermostat
- replaced radiator
- Coolant changed
Things I have checked:
- Coolant is flowing round, the top hose to the header tank gets hot. Therefore the pump is working.
- The oil looks normal, no mayo.
- As the fans are overrunning and the water gauge are both saying it is hot i don't think this is electrical.
Model:
- no fault codes
What I have tried:
- replaced radiator
- Coolant changed
