kyle_h
Major fire risk if trying to regen over 44g just saying
Sent from my iPhone using the Tapatalk app, so that explains the typos...
We are well aware.... thanksMajor fire risk if trying to regen over 44g just saying
I am also trying to reset the ECU for Soot Accumulation due to losing my alternator and driving the battery down, threw all kinds of lights on the dash including the DPF, check engine and blinking glow plug coil. (plus many others) Reading is 50.1 for soot accumulation, need to clear for my emission sticker. Hoping to reset this weekend. Thanks.
I won't bother unless someone plans on doing it...it will probably take me about as long to type everything up as it will for someone to actually do the workOK, let's hear it
Obviously, I wanted to know... thanks for the useless post in warning us that you found a better way that you're not willing to share with the rest of us! I wish I knew this before I wasted my time responding to your PMs to help you!
Here's my view on this, you can take it or leave it. I'm not trying to offend you so don't take it that way. This is a community forum which among other things is here to help those with problems. If people had to seek out a person specifically so solve a problem every time, rather than use a search function to find a previously discussed problem that there's a solution to, this forum wouldn't be nearly as helpful as it is. Posts are stored, stickies are made, and how-to threads are posted for a reason, to help people here. If you have a solution you're not willing to provide to the entire community, then I would suggest not offering it on any terms at all. Just posting you know something and not being openly willing to share it isn't worth the band width the post takes up. There is obviously a need for it or threads like this wouldn't exist. Like I said, take it or leave it, if you're offended so be it, but it's not my intention.First of all, let me say thank you again for the PM, I really do appreciate it! However, after you guys told me how you did (there were two of you that sent me a PM) it I found another way to do it, which will not help if you've already told the computer that there is a new DPF. It seems like you are assuming that this way of doing it will help if the ash level has already been reset, which it will not. Since you've already reset yours, this method won't help at all. Your way is much faster (under 5 minutes) and I thought that it may not be worth it to anyone to spend an hour (or maybe even more) working on their car simply to avoid resetting the ash level, in which case, I certainly wasn't going to spend an hour typing up the steps that no one is going to use. I just posted it in case someone in the future wants to do it.
For sure!Wow. Thanks for taking the time to write this up. May come in handy for quite a few of us in the future.
Bob
Jessemoc's procedure installing potentiometers to trick out the ECM is inadvisable. Granted that the idea of mimicking a thermistor is possible with a potentiometer, but what is missing is the exact resistance setting to start with, the rate of change of the resistance (how quickly to turn the pot), the end target resistance, and more.
The ECM contains an algorithm, and twisting pots as inputs to the ECM without knowing the highs, lows and rates of change that the algorithm accepts as an anticipated value is a waste of time since the program is likely to reject the data as outside the prescribed values and "throw an error code" for that input.
Plus, putting a pot on an AI (analog input) on a printed circuit with chips containing cmos risks blowing the chip which was designed by very knowledgeable folks at Robert Bosch AG who no doubt would completely agree with my criticism of the procedure.
jessemoc, your idea is just that an idea. A nimrod's idea.
Thanks DPM!!!ECU inputs are protected against (and sense for) opens, and shorts to both supply and ground. They are looking for a voltage drop created by the sensor.
What's to smoke?
If it was merely a theory, even what I thought was a really good theory, I would have presented it as such, as I did with option 1.Jessemoc, glad you take criticism well. But have you ever actually attached a potentiometer from radio shack to a Bosch ECM? I thought not.
Your idea may be doable, but until you have actually done it with the exact details revealed and the correct test rig, it is not safe to do with out harming the cmos in the ECU.
Smoke a few ECUs then post the procedure revision.
Yes, a fold back circuit on the input power side. If you want to test it attach a few potentiometers with unspecified wattage and twist the pot. Hell, a faster way to is dyke the pair of wires to the sensor, slowly to draw current. If it passes the test, the ECU will still work, if not then you have introduced an unanticipated amperage to the circuit and trashed your ECU.ECU inputs are protected against (and sense for) opens, and shorts to both supply and ground. They are looking for a voltage drop created by the sensor.
What's to smoke?
The cell that I adjusted only takes a 0 or a 1.... but apparently the ECM cell can be told existing milage in order to come up with a valuecan you just save the value you think it should be? (where you saved 0 )
Just I had suspected, and as I have been noticing from monitoring my SGII, my new driving routine and conditions are causing active regens at a much more accelerated rate. Here's a quick breakdown of how I've accumulated my ash volume since I've purchased the car.That a lot more than I thought you were going to say, which means mine may do the same thing. I've only driven about 7000 miles (~11,000kms) since my change. I check it every once in a while, usually if I'm in VCDS for another reason like a fuel filter change. Last time I checked it was still zero but that still would've been at considerably less mileage than it took yours it seems.
My trips aren't what I'd call long, but it's very flat here so the car doesn't get worked very hard unless I run it hard intentionally. I make a point of getting out on the highway to get some passive regens in, and every once in a while it does an active regen, but not what I'd call often.
I would like to see some proof of your "theory". If you would read this post again http://forums.tdiclub.com/showpost.php?p=4305046&postcount=20 you will see that I was unable to load the car enough to get the DPF hot enough.Having just read this thread for the first time I can suggest a very simple way to elevate exhaust temps.
Do not attempt unless you have at lest a scanguage setup to monitor EGT and DPF temp.
Put on a winter front! block off 90% on air to IC and all to radiator just as IDparts front does. Also use or not interior coolant heater to raise/lower engine coolant temps.
Now on a 40-50F day got out on 4lane road (easiest and uninterupted)and bring car up to 120-130km in 5th and use speed as load adjust. You can easily bring steady state level road EGT up to or over 1000 as well as DPF.Monitor closely as to not overheat, but get as warm as needed for a good passive regen.
ECT will be 205+ and You can hold egt between 1000-1200 deg(and therefore DPF temp also) 30 min of this should drop soot load enough to get back into area where Max thresold lowers enough to allow computer to control regens.
Be careful to not overheat as it is easily attainable to see constant 1400F temp. Constant 1200F will not hurt anything as long as ECT are not allowed to creep too high.
+1The only thing one would achieve by following your advice would be to completely overheat the engine as you're restricting the airflow to it's cooling system.
