redtdi966
2009 Jetta TDI exhaust valve fix
fix-1
Took out valve, on bench worked it open-close with PB-blaster for 10 min then reinstalled two weeks ago, fault has not returned.
fix-2 perminent.
SO thinking the fix is to abrasively remove some of the vane so it does not contact the housing. I think that it binds as exhaust carbon builds up. If I can develop a gap - vane to housing it will fix the problem.
When it fails next time me and the dremel tool will do this.
fix-1
fix-2 perminent.
