Chuck_Norris
- Joined
- Jun 21, 2006
So while I was driving my 2006 Jetta the blower stopped working on all speeds. Later I found that the rear defroster and heated seats no longer work either. The A/C light turns on and off. I have check the 40amp maxi fuse on the drivers side of the dash and ruled out the blower resistor since high speed is inop also. Is there a relay? Thanks in advance
