Old January 24th, 2020, 10:23   #1
prestipresse
prestipresse's Avatar
TDI(s): 2014 Q5 TDI
Fuel Economy: 7.2L/100km
Default Q5 cold air intake upgrade!
Q5 Tdi upgrade air intake or not?
Hi everyone,
I ‘ve had my oem turbo rebuilted: billet, bearings, ..., egr, swirl flap and Add blue delete. New down pipe, cat less. Stage 4 tuning with 4 bar map sensor.
Right now, my turbo is pushing 35 psi.I might have around 300whp, will confirm in the spring with a dyno!
I really need more air for the turbo, suggestion from Tuner!
I want to built my own cold air intake, because it kills me to pay 1000$ for apr cold air intake!
And the opening beside the turbo is so small! I was thinking to fit the SQ5 TDI, it’s much larger then mine, but not sure it will fit!
Do you have any suggestions?
Thanks!
Audi Q5 TDI TECHNIK
Golf 2012 TDI:
prestipresse is offline   Reply With Quote
Old January 24th, 2020, 12:29   #2
Yourbuddysatin
Fuel Economy: 32-35mpg
They come factory with a great intake....
Yourbuddysatin is offline   Reply With Quote
Old January 24th, 2020, 15:42   #3
adjat84th
adjat84th's Avatar
Assuming you have the 2.0 and SQ5 is 3.0? The stock elbow is fairly tiny at the end that meets the turbo at least on my 2.0. Stock is 41mm (I'm sure it's different but maybe similar) on the elbow inside diameter. What I have now matches the inlet on the 2260 turbo while retaining stock airbox. Has to help at least a little bit I'd imagine. My measurements tell me I gained 10mm just by eliminating that elbow...again, retaining the stock airbox.
How about an intercooler upgrade, would help a lot as well I'd imagine.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old January 24th, 2020, 16:16   #4
turbobrick240
turbobrick240's Avatar
Pretty sure all the Q5's got the 3L V6. I think the only Audi that got the 2L (over here anyhow)was the A3.
Old January 24th, 2020, 16:32   #5
adjat84th
adjat84th's Avatar
I guess I could have deduced that from the 35psi mention..whoops. Still think there is merritt to increasing intake size to at least match the compressor inlet though.
Old January 24th, 2020, 17:10   #6
Rrusse11
"Still think there is merritt" to increasing intake size to at least match the compressor inlet though." Adjat
I'll go along with that, I've got a PD150 airbox with bigger MAF going on
my ALH soon, cleaning up the plumbing to the turbo, and larger diameter,
has got to help IMO.
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks
Rrusse11 is offline   Reply With Quote
Old January 25th, 2020, 09:33   #7
prestipresse
TDI(s): 2014 Q5 TDI
Yes I have a Q5 3.0L V6 TDI.
I will mesure the inside of the turbo and of the inlet of the turbo!
I thought the intercooler on the Q5 is large enough!
Audi Q5 TDI TECHNIK
Golf 2012 TDI:
Old January 25th, 2020, 13:17   #8
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
I run the Q5 with gtb2565 and stock intake, 2.4 bar boost 360+ hp , stock intake is perfect.
Big frontal IC surely helps keeping IAT down.
My friend with similar setup runs 400+hp and no need for expensive air intake. He's got probably the fastest Q5 there is 100-200 under 12seconds
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old January 26th, 2020, 05:37   #9
Mongler98
Doing so is NOT and upgrade. It's a downgrade. Hp and engine and turbo killer. Please look at the cold air intakes sticky.
Dont want to match the intake port on the turbo air speed velocity vs CFM. The turbo is doing a fine job as is.
Old January 30th, 2020, 13:37   #10
prestipresse
TDI(s): 2014 Q5 TDI
Hi Macradiators,
Can you tell me what brand and size of IC that is on your Q5?
Audi Q5 TDI TECHNIK
Golf 2012 TDI:
Old February 1st, 2020, 12:58   #11
Macradiators.com
Its something made locally, 700x 300 x70mm tube&fin technology. Awesome and under 150euro here from factory.
CP3 Upgrade
Q5 Intake Upgrade Pittdawg Audi SUVs (Q7 & Q5) and other V6 TDIs 4 December 22nd, 2018 14:57
AFE Cold Air Intake MagnumFORCE Stage-2 Si Pro 5R Intake 2.0 TDI Ffpm46 Private TDI Items for Sale/Wanted 3 August 25th, 2015 09:09
Cold air intake upgrade: Carbonio vs AFE vs APR? mcfarlandrew VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 October 12th, 2014 13:20
Cold air intake upgrade: Carbonio vs AFE vs APR? mcfarlandrew TDI Power Enhancements 4 October 10th, 2014 14:34
Cold Air Intake vs. Short Ram Intake vs. K & N Filter vs. Stock Airbox speedR TDI Power Enhancements 11 January 3rd, 2003 12:50
Page generated in 0.14096 seconds with 11 queries
[Output: 107.40 Kb. compressed to 90.91 Kb. by saving 16.48 Kb. (15.35%)]
