Old January 20th, 2020, 16:35   #1
txarmoredillo
Default 2003 1.9 I t1981 Toyota
Howdy guys ! I am about to begin my toyota swap. I am having a 81 toyota professionally restored, I have a wrecked 2003 jetta tdi. I have so many questions. Can I ask them here? Did I even post this in the right area?
txarmoredillo is offline   Reply With Quote
Old January 20th, 2020, 17:07   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
Looks like the right place.
I highly recommend searching first at the below address as much of this is already covered.
https://cse.google.com/cse?q=+&cx=01...44:_idbzjdyxdm
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old January 20th, 2020, 17:35   #3
txarmoredillo
Thanks sir. FAQ is very basic diesel engine theory, and I am familiar with diesels, as i have only owned diesels my whole life. My questions are more specific towards volkswagen systems. Like what is the thing with two wires coming off the 3rd injector?
Old January 20th, 2020, 17:39   #4
eddieleephd
Originally Posted by txarmoredillo View Post
Thanks sir. FAQ is very basic diesel engine theory, and I have only owned diesels my whole life. My question are more specific. Like what is the thing with two wires coming off the 3rd injector?
This is exactly why I said search the questions there. It's a VW specific search engine.
A simple search there would tell you that injector is used as a sensor, for timing I believe.
It's really very useful and can be found in TDI 101.
On top of that you can search alh Toyota swap and get at least one of those too pop up.
It's my first go to honestly.
Old January 20th, 2020, 17:50   #5
txarmoredillo
Ohhhhh I just realized it's a search engine !!! Thanks !!!!!! Didn't see the search bar up top, I'm on a tablet.
Old January 24th, 2020, 08:48   #6
evguy1
The Toyota is a VERY common platform to swap so you will find lots of info. There are also lots of Rangers swapped and the basic info is going to be the same for all the truck swaps.
evguy1 is offline   Reply With Quote
toyota mounts Was a fordie TDI Conversions 30 August 2nd, 2015 23:49
TD toyota Rockwell Other TDI/Diesel Picture Gallery 2 February 1st, 2010 06:26
Brake job on 2003 Toyota Camry Schwimmwagen General Automotive 16 September 29th, 2008 18:47
1996 Golf TDI or 2003 Toyota Echo? NHVW4ME TDI 101 15 June 2nd, 2008 22:45
Toyota famous VW MKIV-A4 TDIs (VE and PD) 1 June 10th, 2000 07:43
Page generated in 0.17442 seconds with 11 queries
[Output: 76.54 Kb. compressed to 67.22 Kb. by saving 9.32 Kb. (12.18%)]
