C chiro05 Veteran Member Joined Nov 15, 2007 Location KY TDI none Jan 15, 2020 #1 Looking at a clean 2005 wagon but it only has reverse. Won’t go forward? Only wants 700 for it. Steer clear or snatch it up?
C chiro05 Veteran Member Joined Nov 15, 2007 Location KY TDI none Jan 15, 2020 #2 The actual shifter will move to drive but nothing happens in all forward gears.
V vwztips Veteran Member Joined Aug 30, 2009 Location Greenville, SC TDI 2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2011 Tiguan TDI/DSG 2005 Audi A4 Avant 6MQ TDI 2011 BMW X5 35d Jan 15, 2020 #3 Could be a bunch of things. Most likely your options are to a. replace the transmission with a new or used b. convert to a 5 speed Also need to know if the balance shaft has been dealt with. Once things are sorted out, they are great cars.
C chiro05 Veteran Member Joined Nov 15, 2007 Location KY TDI none Jan 15, 2020 #4 I guess cost associated with repair is the big question. It has 300K miles
PickleRick Veteran Member Joined Nov 29, 2017 Location Greenville sc TDI 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress Jan 15, 2020 #5 If you can wrench yourself its worth it if the car is very clean. If you cant and need to pay someone its only worth it if you think the b5.5 is the best car ever made. At 300k the cam should also be inspected.
5 50harleyrider Top Post Dawg Joined Jun 16, 2007 Location charleston,wv TDI 2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual. Jan 16, 2020 #6 I have a nice wagon for sale. PM me
