Old January 13th, 2020, 19:12   #1
Runninwild
Default BHW Pinout
Made a pinout for the bhw if anyone wanted it. might not be perfect, use at your own risk
T94 ECU connector
1. br Ground
2. br Ground
3. ro/gn power supply relay terminal 30 key
4. br Ground
5. ro/gn power supply relay terminal 30 key
6. ro/gn power supply relay terminal 30 key
7. UNUSED
8. UNUSED
9. UNUSED
10. gr O2 sensor heater
11. UNUSED
12. UNUSED
13. UNUSED
14. UNUSED
15. UNUSED
16. UNUSED
17. br/gn closed throttle position switch
18. 12v signal from ignition to wakeup ecu
19. ws Additional heater button?
20. sw/ws cruise control
21. bl cruise control switch
22. UNUSED
23. li/ge Turbo intake temp sensor
24. UNUSED
25. UNUSED
26. UNUSED
27. UNUSED
28. UNUSED
29. UNUSED
30. gn/ro J179 Glow plug
31. UNUSED
32. ws heated O2
33. UNUSED
34. UNUSED
35. UNUSED
36. UNUSED
37. UNUSED
38. bl/gr IAT sensor
39. br/rd throttle position
40. ws/li Mass air flow
41. UNUSED
42. UNUSED
43. ro/gn Clutch pedal switch
44. ro/ge cruise control
45. UNUSED
46. UNUSED
47. ge radiator fan relay trigger
48. UNUSED
49. br/li power supply relay terminal 30 ground signal to relay
50. sw/gr climate control/ac
51. gn/ge O2 sensor heater
52. ro/bl Fuel pump trigger
53. gr/ge turbo intake temp sensor
54. br Heated O2
55. UNUSED
56. UNUSED
57. UNUSED
58. UNUSED
59. gr kick down switch
60. br/ws Mass air flow
61. gr/ge throttle
62. li/sw Charge air pressure sensor
63. ro/ws J179 Glow plug
64. bl/sw Alternator
65. ws/ro brake pedal switch
66. or/br Canbus low signal
67. UNUSED
68. UNUSED
69. UNUSED
70. ws/ge relay for heating coolant high heat output
71. ws/bl relay for heating coolant low heat output
72. gn/sw K wire diagnosis
73. UNUSED
74. UNUSED
75. UNUSED
76. br/sw IAT sensor
77. gr/gn O2 sensor heater
78. gn/ro Charge air pressure sensor
79. UNUSED
80. UNUSED
81. UNUSED
82. gn/br Mass air flow
83. ge/bl throttle position
84. ge/li throttle position
85. sw/ge Defrost idle boost signal
86. ro/gn Starter
87. ro/sw brake light S13
88. ro/ge cruise control button (SET)
89. or/sw Canbus High signal
90. ws/bl Vehicle speed sensor
91. UNUSED
92. UNUSED
93. UNUSED
94. UNUSED
T60 ECU connector
1. br/gn Injector #2
2. UNUSED
3. UNUSED
4. UNUSED
5. UNUSED
6. UNUSED
7. UNUSED
8. UNUSED
9. UNUSED
10. UNUSED
11. UNUSED
12. ro/li Camshaft position sensor
13. UNUSED
14. UNUSED
15. UNUSED
16. UNUSED
17. UNUSED
18. UNUSED
19. UNUSED
20. UNUSED
21. UNUSED
22. UNUSED
23. sw/ge EGR
24. sw/ro EGR
25. ws/ge Motor for intake flap
26. br EGR
27. ro/ws Camshaft position sensor
28. li/bl Camshaft position sensor
29. br/ge N75 Wastegate actuator
30. UNUSED
31. gr Injectors
32. gr/ge Injectors
33. UNUSED
34. UNUSED
35. UNUSED
36. UNUSED
37. UNUSED
38. UNUSED
39. gr/gn Fuel temp sensor
40. gr Fuel temp sensor
41. UNUSED
42. UNUSED
43. li/gn Engine speed sensor
44. UNUSED
45. UNUSED
46. br/ws Injector #1
47. br/ro Injector #3
48. br/bl Injector #4
49. ro/ws EGR
50. sw/bl EGR
51. UNUSED
52. br/ws Coolant temp
53. br/gr Coolant temp
54. UNUSED
55. UNUSED
56. UNUSED
57. UNUSED
58. gr Engine speed sensor
59. UNUSED
60. ws Motor for intake flap
Runninwild is online now   Reply With Quote
Old January 14th, 2020, 06:37   #2
russx
TDI(s): A8 d2
wiring diagram who needs
https://yadi.sk/d/p8vNLbqT3KxrGY
russx is offline   Reply With Quote
Old January 22nd, 2020, 21:17   #3
Alberta 7.3
TDI(s): none yet
Thanks for posting this info. I'm planning a BHW swap project later this year.
Alberta 7.3 is offline   Reply With Quote
Old February 15th, 2020, 15:20   #4
TLOHM
Default BHW Pinout
Runninwild, Your spreadsheet inadvertently has an extra row inserted at Pin-47, resulting in 95 pins. I've been digging through wiring diagrams also and match your list once you back those after Pin-46 down a digit.
TLOHM is offline   Reply With Quote
Old February 15th, 2020, 16:17   #5
Runninwild
thanks I edited it. For anyone wondering the ecu output signals to the fuel pump, rad fans and other accessories are switching ground not 12v
ECU Pinout for BHW? eyebeatbadgers TDI Conversions 6 October 4th, 2019 22:42
ALH/BHW hybrid or BHW with BSM delete? Alberta 7.3 TDI Power Enhancements 3 November 16th, 2017 18:55
BHW A4 swap Performance PD parts 17/22 turbos BHW build parts MARKO P Ported head 2000tdijettafast Vendor & GroupBuy items for sale 1 September 22nd, 2017 19:22
EDC15P pinout ? tdipowersvk TDI Power Enhancements 2 December 26th, 2011 16:29
EDC15 pinout Raxo TDI Power Enhancements 2 September 18th, 2007 20:36
Page generated in 0.13161 seconds with 11 queries
[Output: 70.27 Kb. compressed to 62.54 Kb. by saving 7.73 Kb. (11.00%)]
