Old December 27th, 2019, 08:52   #1
Millennium Falcon
Default 120 pin ALH Tdi analog tach install
I thought this info would fall under the "google it" catagory since it seems so basic.... I i didnt want to ask a question that has been asked a million times so I tried searching it and didnt come up with much. So here are my findings. I realize its elementary but maybe it will help someone.
Ive been using a tiny tach on my ALH swap but really wanted an analog tach. So I looked at my pinout and found that #27 pin of a 120 pin alh ECU is the tach signal. The book says Green/brown wire) It looks like the AHU, and 80 pin ALH have a wire in the harness for tach signal but the 120 pin ALH does not.
The 3rd hole in from the left in the row above the blue wire is #27. This is the larger of the two ECU plugs.
When I disassembled the plug I found the pin to be in place with a small piece of insulation (brown & Green) not sure if this is how all ALH's are or if someone cut mine... I have two harnesses and they both are like this.
Knife is pointing at #27
Here is the pin removed.
I stole a pin and a length of wire from a spare harness......
I put everything back together and hooked it up to the tach. This one has adjustable dip switches but I didnt have to mess with them at all. It was dead on right out of the box.
I compared the new tach with my old tach and VCDS. All is good! Dont worry this engine is in my 71 year old Jeep and will never see 4000 rpm. I chose this tach because its very easy to read from 1500-2550 which is where i usually live.
The final product!
https://youtu.be/9jLoXL-lgGA
Hopefully this can assist someone who is trying to get info on this procedure. Thanks!
2003 Jetta TDI wagon, 5-speed, swap, Sprint520 nozzles 165k
2004 passat 1.8t auto 104k
1949 Willys cj3a ALH tdi swap
Millennium Falcon is offline   Reply With Quote
Old December 27th, 2019, 09:15   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
Awesome write up! Now I know where to point someone
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old December 27th, 2019, 10:52   #3
CasaEd
Pin 27 deffo tacho signal in all 121 pin ECU's, PD included, looks like someone cut the wires in your looms. You can take an analog signal from one of the windings in the alternator before it passaes through the diode, but if you are using the VW alternator it will only read correctly on a VW analog diesel gauge, this is what I have done in my ASZ converted B3 passat.
CasaEd is offline   Reply With Quote
Old December 27th, 2019, 19:58   #4
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Nice!
1.9ZOOK is offline   Reply With Quote
Old December 27th, 2019, 20:35   #5
Millennium Falcon
Thatís what I thought too... several people told me that I would have to add the wire. I was told the 1.8/vr6 have the wire but the tdi does not. I have two harnesses and they are both like this. I removed one from a stock car myself. So Iím hearing and seeing conflicting info.
Old December 28th, 2019, 04:38   #6
jimbote
jimbote's Avatar
https://forums.tdiclub.com/showpost....90&postcount=4
Old December 28th, 2019, 08:51   #7
jhax
Now, that's what this forum has been missing!
jhax is offline   Reply With Quote
Old December 28th, 2019, 11:11   #8
CasaEd
Nice list @jimbote, but I also like to use pin 18 which is the earth switch wire for the ECU control relay
Old December 29th, 2019, 18:03   #9
jimbote
jimbote's Avatar
which ecm are you referring to? pin 37 on the 121 ecm is the wake up wire, then the ecm sends "earth" to relay 109...i'm not short-cutting the factory pathways... can you clarify your approach?
Old December 31st, 2019, 12:04   #10
CasaEd
Pin 37 is the feed from the ignition switch which then lets pin 18 go to earth which energizes the ECU relay which then sends power to the ECU to get it up and running, and yes I'm talking about the 121 pin ECU's, the 80 & 68 pin ECU's also power up the ECU in the same way, but the pin numbers are different,On the 68 pin ECU Pin 38 is the ignition feed & pin 42 earths the EC relay, on the 80 pin ECU pin 47 is the ign feed and pin 33 is the EC relay earth wire. Hope this helps
Last edited by CasaEd; January 4th, 2020 at 12:51. Reason: Incorrect Information regarding pins
Old January 2nd, 2020, 08:57   #11
jimbote
jimbote's Avatar
Pin 37 is the feed from the ignition switch which then lets pin 18 go to earth which energizes the ECU relay which then sends power to the ECU to get it up and running, and yes I'm talking about the 121 pin ECU's, the 80 & 68 pin ECU's also power up the ECU in the same way, but the pin numbers are different,On the 68 pin ECU Pin 38 is the ignition feed & pin 23 earths the EC relay, on the 80 pin ECU pin 47 is the ign feed and pin 33 is the EC relay earth wire. Hope this helps
still confused by your post, if maintaining the stock pathways why would you need to touch pin 18? it's function is undisturbed and not really worth mentioning unless there is damage to the stock wiring.
Old January 4th, 2020, 12:58   #12
CasaEd
Ok, pins 18,42 & 33 is what the ECU sends to earth to enable relay 109 or 53 to send main battery power to the ECU when you turn the ignition switch on i.e pin 37 on the 121 pin ECU. Relay 109 is not turned on by an ignition feed, it has permanent battery feed at pin 30 and when pin 42 is earthed it switches the relay on which in turn sends
power through pin 87 of the relay to pin 23 of the ecu which then turns it on.
Old January 4th, 2020, 17:49   #13
jimbote
jimbote's Avatar
yes, i understand that relay 109 is not directly turned on by the ignition switch, but is grounded by pin 18 of the ecm, so why are you concerned with pin 18? unless you are bypassing the ecm grounding ? and grounding the relay yourself to excite relay 109?
Old January 6th, 2020, 13:57   #14
CasaEd
I did'nt see pin 18 on your list
Old January 11th, 2020, 06:48   #15
jimbote
jimbote's Avatar
It doesn't need to be on the list... i only listed wires and pinouts that require attention when making a standalone harness. The wire coming from pin 18 is NOT one of those because it's path remains undisturbed between the ecm and R109. If you are disturbing that wire, you are taking an unnecessary step.
Analog clock install Passat 03Springer Upgrades (non TDI Engine related) 0 April 14th, 2019 15:55
06 jetta tdi to install cam pin. fluxcore TDI 101 3 July 24th, 2018 06:20
80 pin alh vss pin? pr0cess0r TDI 101 4 February 15th, 2014 11:15
Is it worth updating to a 120 pin ECU? tdibeliever TDI Power Enhancements 9 November 11th, 2009 21:49
1996 1Z TDI Tach Wire Doesn't Operate Mk1 GTI Tach CrewCabCaddy VW MKIII-A3/B4 TDIs 1 April 9th, 2005 16:20
Page generated in 0.17942 seconds with 11 queries
[Output: 130.54 Kb. compressed to 108.95 Kb. by saving 21.60 Kb. (16.54%)]
