Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old November 15th, 2019, 15:18   #1
paperthin
TDI(s): 15 A3 TDI
Default third Brake light Failing
So on my 2015 A3 TDI the 3rd brake light does not come on. I took it off and bench tested it, it is fine. I am about to go out and double check that 12v is going to the connector but not sure if that is going to work. I will scan with VCDS shortly too. Is there fuse I can check? Any other ideas? Everything else is working properly.
2009 Jetta TDI (bought back), 2015 A3 TDI (current)
paperthin is online now   Reply With Quote
Old November 17th, 2019, 08:36   #2
paperthin
TDI(s): 15 A3 TDI
Scanned and got the following which is no surprise.
11274 - Bulb for Center Brake Light
B12C6 15 [009] - Open or Short to Plus
Other places on the internet suggest loose solder on the light. This is not the case as I benched tested it again, and works perfectly, all diodes on bright.
I cleared all faults and will drive on monday to see what comes back.
I am inclined to just let it go for now. Anyone have schematics?
Old November 25th, 2019, 15:25   #3
paperthin
TDI(s): 15 A3 TDI
Well...i haven't figured out what is wrong. I tried to measure the voltage out of the cable connector but had difficulties. The fault comes on immediately. If I figure out anything else I will update. I was hoping it was a loose solder like many people on the internet suggest. The cheapest I can find the light right now is $150 CAD.
Old November 30th, 2019, 18:58   #4
A3Dave
TDI(s): Audi A3
Connector is good? I had my turn signal connector melt a few days ago.
A3Dave is offline   Reply With Quote
Old December 4th, 2019, 08:22   #5
paperthin
TDI(s): 15 A3 TDI
I will take a closer look when I get a chance and report back, I don't think I looked at it close enough.
master brake cylinder failing thundershorts VW Passat Family (NMS and B7) TDIs (2012+) 10 April 19th, 2019 06:59
headlight, fog light, higbeam consecutively failing... HELP! Melvin253 VW MKIV-A4 TDIs (VE and PD) 0 June 23rd, 2012 20:41
G60 brake upgrade and failing VW97JettaTDI Upgrades (non TDI Engine related) 9 November 24th, 2010 10:53
02 TDI Bright/Lowbeam light switch failing? Maizor TDI 101 2 October 29th, 2010 21:57
turn indicator, brake system and failing seat ltz VW B5 Passat TDIs 6 June 29th, 2006 18:04
Page generated in 0.15858 seconds with 11 queries
[Output: 69.11 Kb. compressed to 61.02 Kb. by saving 8.09 Kb. (11.71%)]
