Old November 17th, 2017, 23:40   #1
Stiggy136
TDI(s): ALH 1.9tdi
Default Petrol Diesel conversion
Hi there I was wondering if you could give some advice, my friend has a 1.4 petrol 1.4 Mk4 golf and I have an ALH mk4 golf that I have put off the road the engine is sound but everything else has had it!
We have removed the engine and gearbox out the diesel, fitted new timing belt and water pump, now we want to fit it to the petrol golf.
We have the wiring stripped back to the bulkhead. But there is wiring going into the cabin behind the dashboard. Would it be possible to use the diesel golfs clocks and the petrol golfs wiring to the engine bay? And just use the ALH loom? Rather than pull out both dash boards? Anyone know any shortcuts? Everything is there to make this work. Wasnt sure about convenience module too, Is that coded to the original ECU? We are going to send off the ALH ecu to get the immob deleted. Any advice would be appreciated!
Stiggy136 is offline   Reply With Quote
Old January 14th, 2020, 06:33   #2
Stiggy136
TDI(s): ALH 1.9tdi
Quick follow up cars been on the road 2 years now and re registered as a diesel! Anyone needs any advice give me a shout! there was a lot of trial and error
Diesel less volatile than petrol tdiclubfan TDI 101 20 May 9th, 2012 20:19
Why diesel over petrol? Golf 1 fan General VW Discussion 34 March 30th, 2006 17:26
T4 Swap Petrol engine to diesel revomaster Other VW Group TD(I)s 1 March 20th, 2006 09:53
Diesel is cleaner than petrol ! Willy den CGI VW MKIV-A4 TDIs (VE and PD) 16 May 17th, 2002 06:10
Unable to decide : Petrol/Diesel **DONOTDELETE** General VW Discussion 5 November 18th, 2000 02:46
Page generated in 0.14883 seconds with 11 queries
[Output: 51.72 Kb. compressed to 47.83 Kb. by saving 3.89 Kb. (7.52%)]
