Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Central Canada
Central Canada Local discussions for those between the Rockies and the Great Lakes (Alberta to Manitoba).
Old March 1st, 2017, 10:14   #1
Ovelson
Fuel Economy: 41mpg
Default Question involving a timing belt replacement
Not sure if this is the best place to ask but here goes. I know I need to replace the timing belt on my ALH Jetta (also got the parts for it from Dieselgeek), only thing is I don't have the tools or knowhow to replace it. Question is who would be the best TDI Guru to check with as far as that repair while not having to spend a huge chunk of change?
As for location, I'm about 2 hours east of Edmonton, AB.
Ovelson is offline   Reply With Quote
Old March 6th, 2017, 19:16   #2
Danarm
Danarm's Avatar
Default ALH timing belt replacement
Please find someone with all the right tools, and VCDS too. You will need to check timing. good luck.
If you were closer, I would help.
Dan
Lift pump,11mm IP,R520,17/22,3in OMI,R32 box and maf house, PD150 intake, 2 1/2 straight pipe, with woodpecker muffler,3bar map,stage II colt cam,scan gauge II,boost,egt gauges,Stage V Malone tune,ARP head studs,2001 Golf.
Danarm is offline   Reply With Quote
Old December 30th, 2019, 01:15   #3
JoshArnold
Dan
Hey Dan,
Do you still have tools that I could possibly rent ?
Iím out in hythe and gotta get my 02 alh back together.
JoshArnold is offline   Reply With Quote
Prime after timing belt replacement -off by one question? u20100509 VW MKIV-A4 TDIs (VE and PD) 1 May 22nd, 2010 22:29
Timing Belt Replacement question? dlh TDI 101 7 August 8th, 2009 23:27
timing belt replacement question BeetleLisa TDI 101 4 August 14th, 2006 16:35
Timing Belt Replacement Question rogerpemberton VW MKIV-A4 TDIs (VE and PD) 5 April 26th, 2005 23:04
Timing belt replacement question msaeger VW MKIV-A4 TDIs (VE and PD) 4 July 6th, 2002 01:09
Page generated in 0.12321 seconds with 11 queries
[Output: 57.76 Kb. compressed to 52.48 Kb. by saving 5.29 Kb. (9.15%)]
