Old January 8th, 2020, 14:41   #16
1998993C2S
1998993C2S's Avatar
Fuel Economy: 36 mpg..38, 44.5, 36, 37, 38
Default 1k0 920 973 dx
Gents - Silver Ghost & Lightflyer 1 ~
Many thanks for answering my cluster post. As for the instrument cluster's part number with an X suffix, my records do show a cluster replacement in the 4th year of the TDI's new car warranty; ..4yr/50K mi. .. Who'd a thunk the dealership would use a remanufactured cluster unit? .. Likely such language in the new car warranty fine print.
Anyway, the instrument cluster operates fine during general driving use,, All goes kaputt when selecting any of the steering wheel user convenience items. .. As an example when selecting say, winter tire, nothing happens. (winter tire speed alert/alarm)
Is there any hope of having this cluster serviced? I'll ask TDI fellow member/vendor: Jetta ,97
Cheers, MS
8/'06 Production .. Pkg2 .. Leather .. Navi .. Digital Sound w/Sirius XM .. DSG ..
... KERMA TUNE 1++ ... FSD dampers ... GTI alloy's 17"s ... Pilot Sport A/S 3 ... R.Roll screen ... Dynaudio DSP active amplifier w/Dynaudio Spkr upgrade ... Under-the-radar aesthetic ... A long legged highway sleeper
1998993C2S is offline   Reply With Quote
Old January 9th, 2020, 07:13   #17
SilverGhost
SilverGhost's Avatar
Only time new parts are required is before car is sold new. Any time after that re-manufactured parts are acceptable. Actually it is very common and sometimes new parts are not allowed unless reman are not available.
In this day and age it is very uncommon to find some one with the ability and parts to do that repair for less than the new part costs.
Jason
VW and ASE Master Mechanic. Means nothing without the 15+years working at VW. Also know my way around an aircooled 34 pict 3 or Bosch D-jet.
SilverGhost is offline   Reply With Quote
Old January 14th, 2020, 14:04   #18
1998993C2S
1998993C2S's Avatar
The memory data for my Pkg2 w/navi instruments clusters "Settings" feature is stored where? Any clues?
Using the VCDS to run through the operation of the cluster, (RPM, Speedo, idiot light warnings) is limited. The data for the "Settings" menu is elsewhere. Any clue?
#17 Instrumentation (Cluster): 1K0 920 973 D - Having a malfunction error when running a scan. Clear, and error return's in an instant.
Can bus gateway module: 1K0 970 530 H - no error's
Original vehicle owner - 100% OEM stock, production 8/2006
Cheers, MS
Recurring battery death cattlerepairman TDI 101 14 January 17th, 2012 05:07
Glow Plug #3 recurring CEL code 2TDIguy VW MKIV-A4 TDIs (VE and PD) 3 December 7th, 2008 09:35
Recurring MIL Code - Cyl #3 Glow Plug Heater & another question. ABS TDI 101 2 June 8th, 2006 11:56
Recurring event on calendar not recurring bhtooefr TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 0 March 14th, 2006 15:46
Recurring N146...Can't Clear it! Toronto_Vento VW MKIII-A3/B4 TDIs 14 June 17th, 2004 06:42
Page generated in 0.12528 seconds with 11 queries
[Output: 62.85 Kb. compressed to 56.90 Kb. by saving 5.95 Kb. (9.46%)]
