Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old August 7th, 2016, 16:07   #16
leon10tagg
leon10tagg's Avatar
My wagon with its new wings. Also the car passed the annual mot after I fitted a complete front suspension arm kit and 2 new front tyres. just need to fit the Eibach front anti-roll bar now.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, Newman cam, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Old December 5th, 2016, 14:56   #17
leon10tagg
leon10tagg's Avatar
Eibach front anti-roll bar fitted and I've bought a new turbo feed pipe to fit the CR1756 hybrid I have.....work for me over the Christmas holidays.
The CR1756 hybrid removed from my black Passat as it now has a gtb2260vk fitted.
Also ordered another cam from Newmans this time its a 9.7mm lift version.
Old December 23rd, 2016, 07:34   #18
jtyler
Here is my fairly-new-to-me 2005 Passat. It is bone stock.
jtyler is offline   Reply With Quote
Old December 28th, 2016, 13:32   #19
leon10tagg
leon10tagg's Avatar
My silver passat is turbo-less today as I'm fitting the CR1756 in the morning....
Following this picture I removed the down pipe cut a flap into the side of the cat and removed the cell so in the morning its being welded up again and refitted.
Old December 31st, 2016, 01:17   #20
leon10tagg
leon10tagg's Avatar
Fitted the CR1756 hybrid turbo yesterday and all went well until I went for a drive......no boost. Anyway I thought maybe the vac actuator was sticky, as the turbo has been sitting for about 18 months since I removed it from my other Passat. So I fitted my Mitty vac to check the actuator but movement on the vane rod was fine. So I checked the vac pipes and they all seemed to be ok except I noticed that the tandem pump vac line seemed to be a bit loose. Anyway I went for another drive and this time the brake pedal was solid. So it looks like a vacuum line is loose, off or split between the tandem pump and the servo. So this morning I'll check the pipework to see if anything is loose or split. Hopefully after that I'll get a drive with the cr1756 turbo running 100%.
The CR1756 runs a 56mm compressor with a clip back on the turbine wheel to minimise surge. Also the pad bearing is uprated.
Also the standard 1749va turbo that I removed has no play on the shaft and no oil around it whatsoever so I have a good spare.
Old January 1st, 2017, 14:45   #21
leon10tagg
leon10tagg's Avatar
The finished down pipe......not the best welding...
Downpipe and turbo installed along with a flexi oil feed pipe which I removed from my black Passat
The bulkhead rubber seal between the vacuum lines which I removed from the black Passat to replace the defective one on my silver car.
Fortunately I was able to take some parts of my black Passat which I'll be working on next as the 276 9.7mm lift cam has arrived for it.
Old February 12th, 2017, 01:31   #22
leon10tagg
leon10tagg's Avatar
Bought another ebay special short shifter for the Trendline. Previously fitted one to my Highline and it worked quite well.
Old March 5th, 2017, 01:24   #23
leon10tagg
leon10tagg's Avatar
One of the original pd cans I bought from Newmans wore prematurely. Anyway it took a while for me to get the cam returned for evaluation. However all has ended well as they are going to replace the cam for me with one of their 9.9mm versions. So it will be headed to my Highlines motor and the 9.7mm version which I got recently will go into the Trendline passat.
Old March 11th, 2017, 23:48   #24
leon10tagg
leon10tagg's Avatar
I've now ordered a set of OEM caliper hangers to enable me to fit 312mm discs to my B5.5 Passat. Its due a set of pads anyway as the brake light has just come on and the discs have seen better days. Given that the engine will have a bit more power (hopefully around 200whp) it needs the brakes to be improved. I'm also on the look out for a B6 rear axle with brakes as they are 255mm versus the standard 245mm ones on the B5.5. Not a big difference but it will help to get the car stopped.
Old April 16th, 2017, 18:05   #25
Clroads
Did your bulkhead seal disintegrate? And is that a dealer part? Mine fell apart when I was checking for cracks. Thanks for the photo.
Clroads is offline   Reply With Quote
Old May 15th, 2017, 07:13   #26
jbh110tdi
Originally Posted by leon10tagg View Post
Complete set of StrongFlex bushings ordered for my silver passat to rebush the front suspension before this years Mot. Also hopefully I'll be ordering an Eibach 32mm front anti-roll bar for the car this month and then the rear beam will be braced to reduce roll at the rear.
what bushes does this replace? I would be interested in doing this to my A4 plus my dads A4 eats bushes as he is in and out of a quarry all the time with his car.
jbh110tdi is offline   Reply With Quote
Old March 25th, 2018, 13:53   #27
leon10tagg
leon10tagg's Avatar
Its the complete set for the front suspension.
Old March 25th, 2018, 13:56   #28
leon10tagg
leon10tagg's Avatar
I fitted an Eibach front ARB to the silver trendlie car which has really tightened things up. I've also purchased an Allroad bottom brace for the car which I intend to fit next week.
Currently the car is running with a tuning box and boost controller which provides a lot more torque. At present the car has completed 167k miles and only uses a small amount of oil between services every 8k miles.
Old December 29th, 2019, 10:40   #29
leon10tagg
leon10tagg's Avatar
Its been a long time but work has started on the Passat Trendline again, as its been laid up following thee purchase of a new daily motor. This time I'm fitting StrongFlex rear beam mount poly bushings. The CR1756 hybrid is having a check over and new seals fitted and an uprated camshaft is being fitted. Also a set of refurbished 19" RS6 alloys are being fitted. Then I'll get a couple of pictures up.
Pros/Cons - Passat Wagons, B5 TDI vs. 1.8t sunvalleylaw VW B5 Passat TDIs 26 November 21st, 2014 23:29
Brake Upgrade <312mm , Audi A4 B5/Passat B5 Dankemp Upgrades (non TDI Engine related) 1 June 29th, 2013 09:12
Steel Wheels for B5 & B5.5 platform 100.00 LoneLIPumpeDuse Private TDI Items for Sale/Wanted 1 December 26th, 2007 09:52
Dealer in VA can get A5.5 pkg2's and B5 GLS Wagons ADW_squared TDI Cars for Sale/Wanted 7 September 5th, 2005 17:54
Page generated in 0.21861 seconds with 14 queries
[Output: 130.64 Kb. compressed to 109.88 Kb. by saving 20.76 Kb. (15.89%)]
