Hi Folks,
I picked up a 96 B4 TDI on a few days ago and towed it home.
Owner go tired of it going into limp mode and bought a Suzuki rollerskate car. I ran VCDS and got several codes but the important one is 00575.
I have not driven it yet because he parked it when the left brake rotor 2 round halves separated like an Oreo cookie. Never saw this before so that will be one of the first steps to getting it back to mechanical usability.
There is an exhaust leak near the exhaust manifold. I have not tracked that down yet. I can hear the turbo whining so its spinning free.
I will check the N75 for voltage and Ohms in the next couple days and see what I get. Hopefully it is the problem and a swap will get it back to having normal turbo operation. Of course, the waste gate actuator will need to be checked also.
It should run OK with some tinkering.
The bad, its rusty and the interior is marginal. Im sure the other typical B4 issues will be there with windows/doors. The sunroof is screwed up also. I did move it manually with the emergency tool. Its closed.
Came with 4 studded snows and 4 good summer tires. It has Alum. wheels too.
At 212k miles I think it can be save from the bone yard but before I even consider any major body work or paint it has to be running sound.
Thoughts?
Thanks.............JJ
Thoughts?
