Old July 14th, 2009, 17:59   #1
ssamalin
Default 80k BRM 5m maintenance
waterpump
timing belt
cam check/replacement
consider clocking cam covers
oil, fluids, filters
engine mount check/repair
replace any charge air piping seals (O-rings) if the connections are weeping oil
change gear oil
Flush brake system every 2 years
Check EGR?
check wheel bearings?
check that both of your electric fans for the radiator and air conditioner condensor are functioning
glow plug recall
Am I leaving anything out?
ssamalin is offline   Reply With Quote
Old July 14th, 2009, 18:19   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Do you have an owners manual? A bentley? Get both! 100,000 miles is the accepted interval for the TB on a BRM although I think the OM says 80,000.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old July 14th, 2009, 18:42   #3
ssamalin
Thing is, the OM or the bently isn't hip to mount failure and cam failure and dmf failure like we are. That's why I'm putting together the real world, tdiclub 80K checklist.
Bill
Old July 15th, 2009, 01:06   #4
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
Which mount is failing?
FWIW--I am going to 120000 on the TB..
I just did the DMF and used 10.8 grade bolts and replaced the TTY's which are junk...
Use the dogbone mount insert as well and get rid of another TTY...I got rid of all the TTY's on the dogbone mount and drilled mine to a M14 and got rid of the Dogbone mount failures once and for all...
http://www.rsbdiesel.com/
2006.5 DE DSG, RC2, Sunroof, Rear airbags, 73K miles, 61MPG best.
2005.5 Jetta-5 SP, LSD, Spec S2, 110K, 48 mpg every tank. Best-49.3 mpg-LOCAL. ELF 506 0-30W/15K OCI/37PPM FE, Best=740 MPT, RSB Diesel custom 2.5DP/3" SS exhaust, Synthetic fuel, Koni lowering springs. One of the first Mark V Jettas to hit the street. Pkg 1, MFD, Autowipe, Auto-headlights, Auto-dim mirror, auto-climate. 248C=150HP RC2
2004 6L 89000 19MPG
2000 7.3 388 HP-818 FT lbs Propane
Mach1 is offline   Reply With Quote
Old July 15th, 2009, 01:09   #5
hid3
Banned
Bill
TB change interval is 80k miles. It might be accepted not to change TB at all but that's not the right way to go.
Since BRM is a clone of European 1.9 L TDI engine, here are the maintenances for our engines:
Toothed belt change intervals
TOOTHED BELT CHANGE INTERVALS, TENSIONING ROLLER CHANGE INTERVALS
DIESEL ENGINES
Engine type Engine codes Period Change interval Tensioning roller
TDI-PD
AVQ, AZV,BDK ,BEE,
BJB, BKD, BKC, BXE
BXF, BRU, BLS, BMM,
BMN
since introduction
up to MY 2006
every 120,000 km
up to model year 2006
every 240,000 km
TDI-PD
BKD, BLS, BMM, BMN
from MY 2007
every 150,000 km
from model year 2007
every 300,000 km
PETROL ENGINES
2.0 l
AXW, BLX, BLY, BLR, BVX ,BVY, BVZ,
AXX, BPY, BWA
since introduction
every 180,000 km
hid3 is offline   Reply With Quote
Old July 15th, 2009, 05:38   #6
PDJetta
PDJetta's Avatar
I'd replace the gear oil if its got a manual transaxle.
--Nate
Old July 15th, 2009, 06:57   #7
hid3
Banned
--Nate
x2! I've also done that @85k miles. Mine is a 6-speed manual. Oil was *BLACK* like the sooth would be there...
Old July 15th, 2009, 09:29   #8
PDJetta
PDJetta's Avatar
Also, replace any charge air piping seals (O-rings) if the connections are weeping oil. That's what I did on mine. They are disconnected anyway.
--Nate
Old July 15th, 2009, 20:48   #9
40X40
Experienced
We were discussing the timing belt interval on the BRM engines a couple of years ago.....
Link:
http://forums.tdiclub.com/showthread.php?t=171926
Bill
Old July 16th, 2009, 08:29   #10
hid3
Banned
Link:
Bill
Making the long reading short, what were the conclusions?
Old July 16th, 2009, 15:31   #11
Mach1
SS, which mounts are failing?
2004 6L 89000 19MPG
Old July 16th, 2009, 16:37   #12
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Maintenance
Flush brake system every 2 years.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old July 16th, 2009, 20:22   #13
ssamalin
Thanks for asking. My build date is 06/06 (I have the upgraded mounts that make changing the timing belt easier) and I downshift. I'm just saying I need to check my mounts since I saw a post about them failing. And after reading your post above about your mount fix, I think I'll print it out as an extra how-to.
Page generated in 0.18425 seconds with 10 queries
[Output: 112.70 Kb. compressed to 94.16 Kb. by saving 18.54 Kb. (16.45%)]
