http://www.animegame.com/cars/Oil%20Tests.pdf
Here are some interesting info on different brands of synth oils.
What was even more surprising was Valvoline provided best bang for the buck. It goes to show that Valvoline does know oil.hevster1 said:Many of the oils tested are not readily available in the US. Amsoil was not tested so I wonder how it would have done. Ditto for certain others. Royal Purple is a good product so no surprize there. I am a bit surprized with Red Line as it has proven itself to be top notch over the years. I would love to actually see the test equipment and how it was used.
The dollar sign reflected Austrailian dollars. Street Commodores is a Austrailian automotive magazine devoted to the Commodore car.Powder Hound said:Even if the dollar sign reflected Canadian dollars, the prices were really high, IMO.
The test equipment was interesting, and I have seen references to these tests elsewhere,........
Do you mean "none of those oils are officially approved to work on anything built after 03?" I would not hesitate to run RP in any vehicle, gas or diesel of any model year.wjdell said:.....None of those the oils would work on anything built after 03.
thierryvw said:http://www.animegame.com/cars/Oil%20Tests.pdf
OK - Wish you would use it and do some UOA's if you can do 3 UOA's and all are well we would know if the testing process really means anything. Or is it the quality of Royal purple in that test in not the reality of a engine, and can it protect well in all areas.AZGolf said:Do you mean "none of those oils are officially approved to work on anything built after 03?" I would not hesitate to run RP in any vehicle, gas or diesel of any model year.
