Turbine
Any precautions that should be made when making the change?
Thanks in advance!
Thanks in advance!
And it's been running with conventional oil for that many miles?Turbine said:2000 golf tdi...140k
X2.naturist said:Bringing it to a synthetic after 140,000 miles on conventional oil is bringing it to the party way late.
Not really. Watch this engine last 800,000 miles.naturist said:...Bringing it to a synthetic after 140,000 miles on conventional oil is bringing it to the party way late.
Let the synthetic fanboism begin. A 2000 was originally spec'd to run on normal, then later VW issued a TSB saying synthetic only. Technical reasons probably equal the financial ones, so there's no way to tell if you really _need_ the synthetic. Perhaps crappy OCI combined with crappy dino = dead motors. Perhaps not.Turbine said:Any precautions that should be made when making the change?
Thanks in advance!
As long as the motor in in GOOD mechanical condition and you don't have ANY leaks you can change over. I have changed over many with more than 200K on them. If you have a leak fix it because synthetic flow so much easier it will find a leak real easy. Use and engine flush with a clean filter with the old oil in it. Fast idle it for 20-30 minutes then dump everything and put in your favorite sythetic with a new filter. I would recommend changing the filter early because the oil will continue to clean out the crap. If you are going to be using a group 3 synthetic just change to oil and filter and don't worry about it.Fortuna Wolf said:I've heard that if you are switching from conventional to synthetic you should first use a oil cleaning product. I've heard that a quart of kerosene dumped into the oil works. Let that idle 30 minutes or so to dissolve any deposits and slude then completely drain (don't forget the oil filter housing either) and fill up with synthetic. Be prepared for some leaks and oil consumption for a few thousand miles.
I would NOT do that.Fortuna Wolf said:I've heard that a quart of kerosene dumped into the oil works.
bold statements. care to back them up with some proof?Strjock81 said:I guess this lends credence to the many gentle arguments I have had with numerous brainwashed folks that think since a TDI has a turbo it must absolutely have synthetic oil to survive more than a few thousand miles. Now if they wanted to argue that synthetic is better in this application and make note of the higher than normal EGTs and combustion chamber temps present in the TDI, that's fine, and valid.
But from reading this board, it seems everyone here believes these engines will blow up by the time you get home with 15w-40 in them. While there are some notable differences between OTR turbo diesels and TDIs, TDIs too can run on dino 15w-40 and live reasonable lives. The newer CI-4 and CI-4+ spec oils burn very clean in high temp environments like TDIs, and will leave very little in the way of deposits. They also aren't as liable to coke up and sludge either.
I run synthetic in our TDI, because I believe it is the best option, but that does not preclude the fact that name brand dino oils will perform adequately to get these engines to the point most people will be getting rid of them anyways. I just don't buy that these oils will fill your engine up with deposits, sludge it up, and ruin your turbo in the short or even medium term like some of the big shots on this board preach day in and day out. I am not even sure how much of a problem they will cause long term with decent drain intervals.
So then the next owner can deal with the consequences?Strjock81 said:I run synthetic in our TDI, because I believe it is the best option, but that does not preclude the fact that name brand dino oils will perform adequately to get these engines to the point most people will be getting rid of them anyways.
