ninedee_golf_tdi
Yes, of course, this is a TDI.
This is a completed project I've been working on. I bought it with a spun crank pulley, which is as damaging as a broken timing belt. A trip to the machine shop, some new valves, 8 guides and seals, a light skim and back together it went.
Also replaced:
all cam followers
head bolts
all 7 glo plugs
crank pulley and bolt (no damage to crank nose)
radiator (it looked rotten)
both water flanges
thermostat
all hoses and belts
all vacuum lines
clutch kit (didnt need it, but tranny was out anyway)
complete timing belt kit w/rollers and tensioner
water pump
all seals/gaskets that were needed, including front and rear main
cleaned intake manifold
cabin and air filters
"newer" injectors, new injector seals
new p/s high pressure hose
flushed p/s fluid
added correct coolant
probably some other stuff I've forgotten about (this is the
second time I've typed this, as I lost the first version due to
stupid fingers).
Car is white with tan cloth interior. Interior isnt "new" looking, but very clean and presentable. Headliner is sagging a bit by the "c" pillar on right rear. Sunroof works. Original radio which works.
Car pulls to the right a bit, probably due to goofy tires. They are newer tires, but fronts and rears are mismatched. Since the car isnt titled, I cant drive to town for new tires and an alignment. Has alloy aftermarket rims.
I was going to claim the body was rust free, but after washing it today, I saw 2 spots of dime-sized rust on the bottom of the r/f door. There is NO clear coat peel.
All electrics/windows work. Typical yellowish oem headlights.
My digital camera is in my truck, so no pics are available, but everyone in here knows what a white passat looks like.
I've driven this car about 100 miles around the development here making sure all the buggers are ironed out. Might it blow up tomorrow ? Sure, but I doubt it will. If you don't want to spend $7000 for this car, don't waste yours' or my time. There is a banged up Geo Prism down the road for less money if you want that instead.
VIN: WVWGG83A7TB174461
Miles: 173xxx
A hazy maintenance history from previous owner is included, although after I've done all this work, that history is insignificant.
I drive a tractor trailer and don't get home every night. Be patient if you have a question. I would like this sale to be clean and easy (meaning bank check/cash, and the vehicle disappears within 2 weeks or so).
Why am I selling it ? I own 2 tdi's myself, and bought this to putz with. My girlfriend just can't get comfortable driving a stick, so off it goes.
Also replaced:
all cam followers
head bolts
all 7 glo plugs
both water flanges
thermostat
all hoses and belts
all vacuum lines
water pump
flushed p/s fluid
stupid fingers).
Miles: 173xxx
