Old September 13th, 2005, 07:15   #1
3rs
Fuel Economy: TBD
Default 80K Maintenance
Well its that time. I am looking for a reliable shop in the Dallas area. I don't trust dealers! I think will change the timing belt at 80K also.Ivan
3rs is offline   Reply With Quote
Old September 13th, 2005, 14:07   #2
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
www.runonbeer.com
Robby drives around the state, so try and see when he's up your way...
Yuri.
ymz is offline   Reply With Quote
Old September 14th, 2005, 00:20   #3
TornadoRed
TornadoRed's Avatar
If you're not getting any audible warnings from the TB area, then you should be able to go closer to 100k miles. My Golf TDI needed a new TB before 100k miles, but I had one or perhaps two of the rollers starting to fail. And I could hear the roller bearings starting to grind. Point is, inspect the belt, but if it looks good and sounds good, then you can go longer.
But when the time comes for a new TB, then runonbeer is the man to see in Texas. Whether you live in Dallas or Texarkana or El Paso or McAllen (or OKC).
TornadoRed is online now   Reply With Quote
Page generated in 0.12623 seconds with 10 queries
[Output: 53.23 Kb. compressed to 48.08 Kb. by saving 5.15 Kb. (9.67%)]
