Ported heads problem
ben0069
wales
allroad 2.5 tdi v6
I had my heads ported last year and have had issues with oil leaking down the side of the exhaust valves, either that or between head and valve guide. It then tracks along the roof of the exhaust port and out through the studs that hold the exhaust manifold on and through the exhaust manifold gasket as well as being burned off with whatever goes into the manifold
I replaced new stem seals first thinking it was them but no change, then the heads came off again and I had the valve guides changed and valves checked for tolerance which was all good. While it was in the shop the guy tested for leakage from the top down ie past the stem seal and nothing got past. It is noticeable on both banks and on all 6 ports. I wonder if the porting was a bit to intense where the valve seats or does this sound like a crack.
Any ideas ?
Theguy1084
Charleston, SC
2006 Jetta TDI
I had a head for a 1.8T ported a while back. After porting it smoked really bad and fouled out plugs. I changed the guides and too had no change. Eventually the head was pulled and checked for cracks. The porting weakened and cracked the same area in each port causing oil to get in. Your situation sounds very similar
Mongler98
COLORADO (SE of Denver)
yea need to send your head to frank. I did my own head work but it was more of a light port and polish with a gasket match, i did not change the overall port size other than the last 1/4" of the ports where the gaskets are. If your taking material out of the head like that, leave it to someone who has done this thousands of times with success, not yourself.
100% sure your head is now scrap aluminum! sorry.
South of Boston
Since the OP is in Wales I kind of doubt it's worth the expense of sending a cylinder head to Missouri. I'm guessing there are adequately skilled people in the UK that can port a head.
mrchill
TDIClub Enthusiast, Super Secret Diesel Ninja Vend
MASS! home of THE WORLD SERIES CHAMPION RED SOX! x
96 B4v red \ 98 Mk3 green\98 Mk3 Jetta black\ 99 Mk4 Jetta green x2\ 99 Mk4 Golf silver x2\ 99 Mk4 Jetta black\ 97 B4 sedan green\04 JSW gold\03 JSW silver
There are many competent porters in Europe....see if one has a head already done for you so you dont have to find a good core.
Mongler98
NA, its not expensive, you gata get one of them container ships that loads things for pennies. it may take 3 weeks to get to him but i have shipped and been shipped things like this for about $25 bucks, china can ship this to you for $0.10 though lol
mrchill
Its more than you think...even by ship. And if you dont insure it...you may find yourself in a bad way. Besides, with a couple of exceptions...the good porters are in Europe anyway.
Enabled
Houston, TX
2003 Jetta TDI Manual, BMW 328d SW
OT:
China shipping to US is actually subsidized by the US government, and we are all paying for the "free shipping" of junky fidget spinners.
/OT
[486]
MN
02 golf ALH
know what an 0a6 transfer case from the UK runs? $200 in shipping alone
Know what a transmission costs? Hell if I know but I feel like I got it for a steal at $1k for the trans and shipping
Know what four pistons cost to get shipped from there? $60
Shipping is hideous expensive.
ETA: to the op, run a crankcase evac pump, it'll pull the oil back in, haha
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
Ben0069
Get in touch with dark side. I ordered an alh head from them and they used a local machine shop for all the work I had done. Just my $.02.....
ben0069
wales
allroad 2.5 tdi v6
Hi all,
thanks for your input, the shop I used for the porting I thought had a good reputation, it was cnc done, I have sent him a message but I'm not going to hold my breath, thinking he may want to help.
darkside is a good shout, I will ask them
Mongler98
3 years ago when i contacted a scrap yard in UK who had a PD150 i purchased, had it shipped to USA for $12.00.
leon10tagg
Northern Ireland
2001 Golf 90bhp ALH tdi, 2002 Golf PD100, 2004 Passat 1.9PD AWX, 2001 Golf 4-Motion, 1997 Audi A4 1.8t sport, 1998 Subaru Impreza 2.0t WRX
Hi all,
Who did the head work?
GOFAST
nederland
vento afn
I had simular problems.
Did your man check the tolerance with the camshaft in it?
And do you use a hi lift camshaft ?
vtpsd
Vermont
03 jsw TDI, audi 90 AHU swap
Could you go into a bit more detail? I used a stage 3 colt camshaft and ported my own head and had the exact same issues as the original poster.
How did your high lift camshaft cause issues?
turbovan+tdi
Abbotsford, BC.
2003 TDI 2.0L ALH, auto, silver wagon, lowered, Colt stage 2 cam, ported head,205 injectors, 1756 turbo, Malone 2.0, 3" exhaust, 18" BBS RC GLI rims. 2004 blue GSW TDI, 5 speed, lowered, GLI BBS wheels painted black, Malone stage 2, Aerotur
This. Not really fixable so sadly, you are looking for another head.
ben0069
wales
allroad 2.5 tdi v6
No hi lift cams, just stock and I'm not sure about checking tolerance with cams in, I will have to ask
bhodgkiss
Banbury, UK
AFN Passat Wagon
ive used a company called CylinderHeadDevelopments in the midlands (UK) for porting my AFN, 7 years later and 60k miles and still good,
GOFAST
nederland
vento afn
In my case i used volvo exhaust valves.
They ware 1mm shorter, so i used 1mm lash caps to fill the space between the valve and the hydro tappet.
My cam had one mm more lift, combine the two and i had a problem
Do not know te correct name for this part in english.
But it came in contact with the valve seal.
Like this.
I search't a long time for i found it.
Becouse if you take the head off it looks just fine
vtpsd
Vermont
Like this.
Thank you very much for the explanation and the pictures. I wonder if I could have an issue like that with my AHU that started loosing oil around all of the valve seals quite badly.
The parts that you show are called "valve keepers" or just "keepers" in English because they 'keep' the valve in place. They probably have a more technical name, but I am not sure what it is.
ben0069
wales
allroad 2.5 tdi v6
Thanks for that.
Layerz, it's both heads.
vtpsd, They are called 'collets' or valve cotters, usually referred to as valve keepers as you said
DCautosport
Portugal
Seat Leon FR 1.9 150cv TDI
Ccheck a company name "Veicomer" in Portugal .... maybe be surprised with their work ... have facebook with many videos, I'm sure everyone will like it.
ben0069
wales
allroad 2.5 tdi v6
The place where I had the heads done have agreed to have them back and inspect them, will let you know what they come up with.
Franko6
Vendor , w/Business number
Sw Missouri
Jetta, 99, Silver`
Hey, I'm not against doing heads for people in foreign countries. It would not be my first... But even saying that, I wouldn't recommend sending stuff over here. Besides that, you'd have to wait. Backlog is my biggest problem.
I have been criticized for my work from 'the professionals'. I can take it. Some of the 'constructive criticism' is actually just plain wrong. I keep doing what I do. Many understand and appreciate our goals and concepts. It's not like we haven't learned from others mistakes and even more, from our own.
Going big is fine, but anyone without the tooling and experience can find a casting that has porosity. The bigger mistake is thinking 'maximum CFM' wins the race. I believe max porting means you eventually will crack a port. Particularly susceptible are the outside of each end's exhaust port. Other than that, going big also means head lift. We have seen and heard of many ideas that are 'off the chain' to control the lift, but the obvious issue is not enough head bolts.
Whatever does happen, I think we all would like to hear what the issue ends up being.
