banshee365
Hey guy's! New member here. I've been surfing the board for a while and finally decided to join based on, what appears to be, a very large amount of experience and knowledge.
This is our first TDI but not our first VW. My wife had an '05 Beetle convertible with the 1.8T for 6 years until we got the Passat in July.
I'm used to doing 5k oil change and am comfortable with that interval. I know the issue I'm about to bring up has been beat to death but I'm still unable to find an answer to my exact question. VW's recommendation is 10k oil changes. I feel that if the oil was sent off to a lab at 10k it would still be just fine. But, for the somewhat small cost of changing it, I would like to at 5k. Especially on the initial break-in oil. I'm sure the filter is good enough to filter out the break-in material, or whatever is left after whatever the factory does to run the engine after assembly.
My main question is, is the oil from the factory a certain type of oil that should be left in for the first 10k miles to allow a correct break-in, or is it just your regular recommended Castrol oil? If the oil isn't anything special I think I would like to change it before the "free" service at 10k.
I look forward to seeing the responses and I'm not trying to start anything here, just a general discussion regardless of if the oil still serve's it's purpose at or past 10k miles.
