Old March 25th, 2020, 08:01   #1
Phi1osopher
Phi1osopher's Avatar
Default Solid Urethane bushings beam/rear axle will these Golf/Jetta ones fit a Passat B4V?
I'm trying to sort out if these rear beam bushings that fit all the mid 1990's Jettas and Golfs will also fit my 1996 B4V Passat.
So I am working on Tulbirt, my 1996 B4V TDI Passat, and am creeping up on getting all the suspension and steering components sorted out. I'm almost done! This last run of ordering parts should be everything (for now): ball joints, motor mounts, front control arm bushings, seat glide bushings, and the rear beam bushings. I like the idea of solid rear beam axle bushings, and found these on the interwebs. They are sold by Whiteline out of Australia (or locally on eBay) for about $60 shipped.
Whiteline - W63391
https://www.whiteline.com.au/product..._number=W63391
Phi1osopher is offline   Reply With Quote
Old March 25th, 2020, 22:00   #2
Steve Addy
TDI(s): 97 Mk3
Whiteline - W63391
I used their websites (the US version too) and searched on make / model etc and didn't come up with the parts your showing here. I'm not sure what they go to but the W63391 doesn't show up as being for B4 Passat, at least for me.
Steve
the magic triangle spins in the peanut and then apex seals come out
Strava
Old March 26th, 2020, 05:53   #3
Abacus
That helpful B4 guy
Abacus's Avatar
Fuel Economy: And the miles just keep ticking away
I have replaced literally dozens of B4 axle beam bushings, and do not think those will work. Based on the design, the axle beam bushings help center the axle beam and prevent lateral movement. It does not look like those work that way. They also help counter torque steer through braking and cornering, which is why the stock bushings are designed the way they are, and mounted 180 degrees opposite one another. I used to do so many we even made our own tool to use, which made things so much easier. It's currently on loan to TDIL3dad.
'97 B4: 453,000 miles FOR SALE! Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
'96 B4V: 356,000 miles Malone 2+, PP520's, 6 speed, 02J short shifter, E-Codes, G60 brakes, Evo plate, DMF, stainless exhaust, heated leathers, cold weather package
BUG*PWR 2013 Award Winner
Abacus is offline   Reply With Quote
Old March 26th, 2020, 20:47   #4
Phi1osopher
Thanks for the info!
Rear Axle beam bushings.. Which ones? G Men 08 VW MKIV-A4 TDIs (VE and PD) 7 October 27th, 2014 17:35
Rear axle beam bushings SkyRyder55 VW MKIII-A3/B4 TDIs 20 June 23rd, 2014 21:58
WTB MKIV solid rear beam bushings and install tool Redneck Truck Private TDI Items for Sale/Wanted 3 March 29th, 2013 12:05
Original rear axle bushings, were yours solid? 03Springer TDI 101 3 April 26th, 2012 07:27
Rear axle beam bushings, Need help Rob02f350 TDI 101 15 April 3rd, 2011 15:53
Page generated in 0.15667 seconds with 13 queries
[Output: 67.52 Kb. compressed to 60.62 Kb. by saving 6.90 Kb. (10.22%)]
