Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old January 14th, 2020, 14:37   #31
Brokein2
TDI(s): 2015 Q5
Thanks DieselDeeds....I was hoping you would say that. I will get it on my to do list for spring.
Brokein2 is offline   Reply With Quote
Old January 20th, 2020, 09:40   #32
Pittdawg
Originally Posted by Huskies2710 View Post
Well my shop just sent out their New Year's specials on performance upgrades. Time to make some calls and see what they suggest on the Intercooler for the A6.
Pittdawg you the only one who made that SQ5 upgrade?
As far as I know. I found some blog post from Slovakia describing the process and just went for it.
Pittdawg is offline   Reply With Quote
Old February 7th, 2020, 17:23   #33
Brokein2
TDI(s): 2015 Q5
Why wait for Spring? Found a great deal on a Wagner intercooler...
Car definitely likes breathing cold air. Hardest part of the install is getting the old hoses off as this one comes with new ones.
Old February 8th, 2020, 08:54   #34
DieselDeeds
Fuel Economy: ~31mpg AVG
Nice- That looks awesome! Install was pretty straight forward after the bumper was removed right? My next project is having a custom fab crashbar made to replace the huge one that blocks off a huge part of the intercooler. I have a close friend who owns an engineering and fab shop and I’m hoping (as long as he doesn’t charge me for too much ) to get something fabricated like the one below—>
DieselDeeds is online now   Reply With Quote
Old February 8th, 2020, 15:14   #35
Brokein2
TDI(s): 2015 Q5
Yep...bumper comes off no problem. I have looked at the area blocked by the actual aluminum bumper and even with it there, the area of the new intercooler is still more than twice the original. As seen in this picture below, even if you removed the aluminum bumper, the external plastic "bumper cover" that holds the license plate would still block the air from a direct shot through that part of the intercooler.
A bar like that might ok as long as it still ties into the sacrificial mounts on the front of the frame but the small diameter would have a hard time transferring the kinetic energy of an impact over a long distance. Maybe if it was 2.5 OD with a .250 wall, it could do the job. That is a great idea though...
Old February 8th, 2020, 15:21   #36
DieselDeeds
Very good point and I’ve thought about that. I’d be upgrading to a honeycomb front grill if I made the crashbar step!
Old March 25th, 2020, 12:03   #37
DieselDeeds
The next mod has come! Vogtland springs that lower 1.2 front and 1.2 rear. From talking to a guy at Urotuning (which has the best price btw), he said the springs are slightly stiffer than stock and not nearly as stiff as h&r. I’ll be installing them these next few days and will give you my reviews.
Old March 26th, 2020, 06:41   #38
Daemon64
Fuel Economy: Fuelly Average 29.6
Nice man. Love the idea of the springs. Any reason you didn't get bilstein b8's to match them ( I think it's the b8s that's for lowering.... if not it's the b6s). I've heard that the bilsteins make a world of difference w/o sacrificing comfort.... Also when your good to go can you please comment on comfort, handling, and MPG... I've heard that it can help highway. I know looks and all... just curious.
Keep up the awesome work!
Daemon64 is offline   Reply With Quote
Old March 26th, 2020, 08:42   #39
DieselDeeds
Hey Daemon,
I went with just springs rather than springs + bilsteins for a few of reasons.
1. I wanted to keep my stock struts because they offer the adjustable ride dampening (comfort, auto, dynamic, and custom). If I wanted to keep the adjustable ride dampening and get new struts, I would have to go with some pretty expensive struts as I think the only adjustable ride dampening struts I found for the Q5 TDI were $250 more than the regular struts w/o magnetic dampening. When the time comes and I install the spring that I just bought, if they are too stiff and I am not pleased with the ride quality, I will look into getting the adjustable dampening new struts for my springs or just revert back to stock
2. I don’t want to drop my ride height a lot. Even with h&r’s drop height being 1.6F and 1.5R, I was almost seeing that as barely too much of a drop. Seeing as Vogtland springs only drop 1.2 front and rear, I saw that as the perfect middle ground for drop height. I know the difference is very minimal but that’s slightly more than 1/4 inch in the rear and almost 1/2” for the front.
3. This is The primary reason I chose Vogtland. I think the springs could be a “undiscovered” gem in the Q5 TDI world as I never see discussions around them. They could be perfect for people who don’t want much of a drop or too harsh of a ride. I’ve read a lot of people (almost all from what I’ve read on forums) have gone with h&r springs and I’ve heard mixed results from “they’re amazing” to “they’re too stiff so I went back to stock”. From everything i’ve searched on the Internet and forums (and I’ve been looking around for about a year), I have found nothing on the Vogtland springs. So I’m partly doing this is as a guinea pig and I’m hoping to have good results to share for those people who are similar me and don’t want too stiff of a ride. After talking to the guy at Urotuning, he told me they’re very similar to stock and not nearly as stiff as h&r, which is exactly what I’m looking for. In the end, if they’re too stiff or I don’t like them, I’ll go with bilsteins or revert back to stock if I don’t like them.
Old March 27th, 2020, 06:29   #40
Daemon64
Diesel,
That makes a ton of sense. I didn't even consider the adaptive.... hahaha I don't have them so for me it's an easy and cheaper jump. Looking to hear on the vogtland springs. I'd rather do a minimum drop as well... like having good ground clearance....haha. Plus the other half doesnt agree with dropping it at all "Its an SUV, kinda defeats the purpose doesn't it?". So I have to find minimum drop when I do mine... hahaha
Old March 27th, 2020, 08:27   #41
Pittdawg
Originally Posted by Daemon64 View Post
Diesel,
Now I am thinking of a mild raise to throw on some big tires for the zombie apocalypse!
Old March 27th, 2020, 10:10   #42
Daemon64
Don't Forget something like this:
Old March 27th, 2020, 16:40   #43
DieselDeeds
Haha totally man! My brother is the complete opposite of me- he lifts everything he’s ever had, which is totally fine. I just don’t have a reason to lift any of my rides as the most adventurist I get is heading up to the mountains to ski and driving some groomed, bumpy, national forest dirt roads that lead up to a hike.
Oh nice! I’d love to do that but I just don’t have a reason to. There’s a Touareg on these forums that has a lift on his- it looks amazing
Old March 29th, 2020, 11:17   #44
DieselDeeds
Default Question! Just straight piped my Q5– Turning into Deeds’ Q5 TDI Ownership Log
Alright- Vogtland springs are installed! I put them in yesterday with my neighbor. I will outline the steps we took (with pictures that I took during removal and installation) at a later date but for now, here is the before and after.
Before:
After:
Initial thoughts after installation:
I took the Q5 out for a drive and noticed driving on the road hasn’t changed much during normal, everyday driving, when in auto or comfort (maybe a smidge stiffer in auto). When I put the car in dynamic or auto and hit turns hard- the difference was huge! Especially when in dynamic. The car is much more fun to drive and sits perfect (in my opinion). I will post steps with pictures later
Old March 30th, 2020, 06:13   #45
Daemon64
Hey Diesel,
My other half and I were looking at the pictures. Looks really nice man. Even she doesn't mind the mild drop. I got to say though, that black optics package looks damn nice on that car. I never noticed it before / even thought to look since I was just trying to get any q5 diesel at the time... hahahaha... Looking at your car it amazes me how much chrome is on mine now. So funny.
I like the look, still not sure about dropping it or not myself. But you've ratcheted me 1 point in that direction... hahaha I'm curious about your alignment after and such.
Tdi's with no mufflers and straight piped Tdidiesel02 VW MKIV-A4 TDIs (VE and PD) 6 November 29th, 2015 06:15
Straight piped 73veedubya VW MKIV-A4 TDIs (VE and PD) 41 January 31st, 2014 12:30
Straight piped my golf (videos) konrad VW MKIV-A4 TDIs (VE and PD) 26 August 29th, 2013 09:12
straight piped... 04GULFTDI TDI Power Enhancements 24 November 2nd, 2010 21:26
Page generated in 0.17408 seconds with 13 queries
[Output: 130.80 Kb. compressed to 110.30 Kb. by saving 20.50 Kb. (15.67%)]
