Old September 28th, 2012, 09:50   #46
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
yes mine are ngk.
2013 f150 Ecoboost 157" WB tuned
2009 Bmw X5 diesel... stock for now
2012 Jetta Tdi Dsg bone stock..for now
2002 jetta tdi 5 speed TD tuned 48.6 avg. SOLD
1999 beetle 5 speed whitbread built. SOLD
2002tdi is offline   Reply With Quote
Old September 28th, 2012, 10:27   #47
lynnejohn
Fuel Economy: 46
With the Malone stage 2 I also had the Dynamic EGR added which is supposed to shut off the EGR when engine temp reaches 150F. Funny thing is when I look at my VAGCOM log I don't see the EGR going to 0% when the engine is at temp. I'm trying to get in touch with Mark to see how this EGR thing is supposed to work.
lynnejohn is offline   Reply With Quote
Old September 28th, 2012, 15:14   #48
thundershorts
hey! its the surprise de jour! anything else? perhaps you'll just have to get used to its quirks with the mods.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old September 29th, 2012, 20:48   #49
lynnejohn
Fuel Economy: 46
It happened before the mod was put in so I knew the issue was still there (but it has gotten slowly worse.) I ran another log for a few minutes this morning and comparing the time and temp of when the EGR goes to 100.6.
-Run--Time--Temp
26Sep 131.8 34.2C
29Sep 124.6 27C
I don't see anything here plus the Dynamic EGR is most likely clouding the issue. I'll run with the original ECU to see if it is exactly the same as 2002's.
Old September 30th, 2012, 05:46   #50
thundershorts
not sure what you meant by "same as 2002". sounds like a plan...good luck
Old September 30th, 2012, 11:49   #51
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
he is talking about same as me.
Old September 30th, 2012, 18:49   #52
lynnejohn
Fuel Economy: 46
Original ECU:
- Rough idle is not there.
- EGR acts exactly the same as with the Malone tune.
- @127.67 Seconds, 28.8C, EGR goes to 100.6.
Whatever is causing the rough idle does not seem related to the EGR %. At this point I can only ask Mark what his opinion is as to the cause and hope he has something good. 2002tdi I hope that what we are seeing is the same problem as it would be nice to solve this (I want my extra torque back and you would like to have a normal idle.)
Old October 1st, 2012, 03:28   #53
thundershorts
how does it run compared to running with the tuned ecu? Is the dynamic egr part of the tune? Maybe the dynamic should be a delete.
Old October 1st, 2012, 07:46   #54
lynnejohn
Fuel Economy: 46
Quick update,
Car started/idled fine this morning, drove down 1/2 mile to my local gas station to get some coffee. Came back to the car and after starting it, it began to idle roughly. Did that for over a minute until I decided to leave for work. I'm really not sure what to think at this point but I might try a couple of things if they are cheap enough. First on my list was the injector wiring loom that had been mentioned in another thread as giving a lot of poor running issues until the car was stopped and restarted and then all was fine. I really don't like taking shots in the dark, but I'm beginning to get tired of this issue and the loom is about $50.
Old October 3rd, 2012, 10:57   #55
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
i was thinking last night and am wondering if this has anything to do with the intake manifold having excessive carbon build up. also i noticed while driving some i am doing 40-50 mph and its in 4th gear. it kinda jerks around or shutters so u either have to speed up or downshift
Old October 3rd, 2012, 21:41   #56
lynnejohn
Fuel Economy: 46
2002,
You said you MAF was cleaned right? I think I rather do some cleaning before paying 60 for the wiring harness. But just to let you know that with the original ECU software on cold start-ups, it takes about 20-30 seconds before the idle becomes rough. It will idle for 3 minutes that way before I have to run to work(meaning I don't really know how long it would go on if I just sat there.) I still have not heard from Malone Tuning.
Old October 4th, 2012, 06:29   #57
2002tdi
2002tdi's Avatar
Fuel Economy: 38ish
my maf was also replaced and swapped with another known working one and nothing changed.
Old October 4th, 2012, 15:34   #58
thundershorts
you could just unplug the maf and run it. you can clear the fault later
Old October 8th, 2012, 07:33   #59
mcinfantry
Mine idles rough, but not every day. my mileage has dropped a good bit too...
mcinfantry is offline   Reply With Quote
Old October 8th, 2012, 11:50   #60
perry-vw-
My 05 has been doing the same thing, rough idle and even smoking on cold start ups. The car is all stock with a BSM completed last spring. I was talking to a friend with a TDI Touareg about my problem and he asked what type of fuel have I been using. I told him that I fill up a Road Ranger and he said that their "crap fuel" could be causing my problem. As I got closer to needing fuel I thought that his idea was too simple and I should try a different brand to prove him wrong. I filled up at Shell and within a couple of days I noticed the rough idle wasn't as bad and the smoking was less. I have filled up at Mobil 2x since then and I have noticed a huge improvement. The rough idle is there just a little bit but it goes away very quickly and the smoking is gone.
I don't know if this is just a coincidence but it is worth a shot.
perry-vw- is offline   Reply With Quote
2005 Passat TDI - Rough Idle Problem gtalum VW B5 Passat TDIs 31 August 1st, 2012 05:25
2005 passat TDI running rough captaindlowe TDI 101 9 October 19th, 2011 05:37
Rough idle when cold - 2005 Golf TDI Leebro61 TDI 101 9 July 18th, 2011 06:53
Low pwr, rough idle, sputtering in 2005 PD Zampano77 TDI 101 14 January 3rd, 2010 18:15
2.0 rough idle question POWERSTROKE VW MKIV-A4 TDIs (VE and PD) 5 August 28th, 2003 14:31
Page generated in 0.16908 seconds with 11 queries
[Output: 125.72 Kb. compressed to 105.00 Kb. by saving 20.72 Kb. (16.48%)]
