Old September 24th, 2012, 21:40   #31
thundershorts
engine temp
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old September 26th, 2012, 08:56   #32
lynnejohn
Fuel Economy: 46
I have the log file, now what? It is from startup to shutdown on my morning commute (35 minutes.) Should I plot it on a graph for say the first 5 minutes?
lynnejohn is offline   Reply With Quote
Old September 26th, 2012, 11:39   #33
thundershorts
why not just look at the eng temp to see if its erratic or consistent. that may rule out the temp sensor. you also might, with engine idling, rap the egr valve with a hammer handle to see if it comes unstuck, smoothing out the idle. I suppose you still haven't removed it to clean.
Old September 26th, 2012, 12:40   #34
lynnejohn
Fuel Economy: 46
It was cleaned by hevster1 when my BSM kit was put in about 5000 miles ago. I could recheck it. As far as the engine temp it was taken as Coolant - Temperature (G62) ranging from 21.6 at startup to low 70' - low 80's on highway:
Old September 26th, 2012, 13:51   #35
thundershorts
Its too bad you don't have another one known good you could change it to see if its the valve malfunctioning. temps seem normal. It does appear that as soon as the egr shows open, your engine smooths out during warmup
Old September 27th, 2012, 08:48   #36
lynnejohn
Fuel Economy: 46
Post
At startup the EGR is at 100.6 for 4 seconds
Time C Time /min MAF spec MAF act EGR
0.01 21.6 0.17 0 650 0 100.6
0.33 21.6 0.51 0 650 0 100.6
0.69 21.6 0.86 0 650 0 100.6
1.02 21.6 1.2 0 650 0 100.6
1.38 21.6 1.55 0 650 0 100.6
1.73 21.6 1.9 0 650 0 100.6
2.07 21.6 2.24 0 650 0 100.6
2.42 21.6 2.58 0 650 0 100.6
2.75 21.6 2.94 0 650 0 100.6
3.1 21.6 3.27 0 650 0 100.6
3.45 21.6 3.63 0 650 0 100.6
3.81 21.6 3.97 147 650 30 100.6
4.14 21.6 4.32 735 585 475 100.6
4.49 21.6 4.67 987 275 380 61.9 <--Why now?
4.83 21.6 5 903 280 320 48.1
5.19 21.6 5.35 819 365 365 71.4
5.52 21.6 5.71 861 310 355 38.3
5.88 21.6 6.05 840 325 335 31.6
6.22 21.6 6.39 819 390 325 67.9
6.57 21.6 6.74 924 290 320 15
6.92 21.6 7.08 840 345 320 55.2
7.25 21.6 7.44 882 300 315 18.9
7.6 21.6 7.77 861 320 340 52.5
7.95 21.6 8.13 861 300 300 21.3
8.3 21.6 8.47 861 325 310 57.2
8.64 21.6 8.82 903 280 290 16.2
8.99 21.6 9.17 882 300 305 46.9
9.33 21.6 9.5 798 370 310 69.4
9.69 21.6 9.85 882 285 285 51.7
10.03 21.6 10.2 882 280 295 56
10.36 21.6 10.54 861 295 285 63.1
10.71 21.6 10.88 798 370 305 82.5
11.06 21.6 11.23 861 295 285 71
11.4 21.6 11.57 861 315 295 75.8
At 131 seconds later it goes back to 100%
123.71 33.3 123.88 840 270 270 72.2
124.05 33.3 124.22 861 265 275 68.6
124.4 33.3 124.57 861 270 280 70.6
124.74 33.3 124.92 882 260 280 68.3
125.09 33.3 125.26 903 250 230 67.9
125.44 33.3 125.6 840 275 285 72.2
125.77 33.3 125.96 819 280 295 71.4
126.13 33.3 126.31 903 250 250 68.3
126.47 33.3 126.65 882 255 255 67.1
126.83 33.3 127 840 290 265 77.7
127.19 33.3 127.35 840 275 295 72.2
127.52 34.2 127.7 882 265 270 70.6
127.86 34.2 128.04 861 265 255 69
128.21 34.2 128.38 882 260 250 68.6
128.55 34.2 128.72 882 260 260 70.2
128.89 34.2 129.07 861 270 265 71.4
129.24 34.2 129.42 861 265 275 71.8
129.58 34.2 129.76 882 260 265 68.6
129.94 34.2 130.1 861 265 265 70.6
130.28 34.2 130.45 840 275 280 71.8
130.62 34.2 130.79 840 270 275 70.6
130.96 34.2 131.13 840 270 265 71.8
131.3 34.2 131.47 882 250 250 65.5
131.65 34.2 131.82 840 275 275 100.6
131.99 34.2 132.17 903 245 460 100.6
132.33 34.2 132.5 861 245 485 100.6
132.69 34.2 132.85 861 240 480 100.6
133.02 34.2 133.2 861 240 460 100.6
133.38 34.2 133.55 882 240 460 100.6
133.73 34.2 133.89 861 240 455 100.6
134.07 34.2 134.24 861 240 445 100.6
134.42 34.2 134.58 861 240 465 100.6
134.76 34.2 134.94 861 240 475 100.6
I don't see anything changing (temp/MAF) when it finally goes to 100%. Is there anything else that can be seen from this data or should I look at some other sensors?
Old September 27th, 2012, 13:44   #37
thundershorts
has your car had the ecu software upgrade and ngk plugs installed? any tuning?
Old September 27th, 2012, 16:45   #38
lynnejohn
Fuel Economy: 46
Malone Stage 2.
Old September 27th, 2012, 23:34   #39
thundershorts
Maybe you are getting closer to fixing the problem. The ecu software dictates the egr operation based on various inputs. Perhaps you should speak to your tuner. Had we known this originally, it would have been less time consuming and frustrating for you. You might also, if not already, have the voltage and glow times set to accommodate the ngk gps, as we are going into colder weather soon.
Old September 28th, 2012, 05:36   #40
2002tdi
2002tdi's Avatar
mine is BONE stock. and it does the exact same thing. i thought it might have been doing this because of the EGR valve cycling and if i had the car tuned it would eliminate this issue... but then again if yours is tuned and it still does it so that kinda eliminates that solution. like i said i have been dealing with this for almost 9 months now. and now that it is cold its seems worse. also all of my coolant temp sensors are up to par. lets work through this...im tired of my car doing this.
2013 f150 Ecoboost 157" WB tuned
2007 Mercedes benz GL320 cdi
2015 Passat Tdi bone stock mid
2002 jetta tdi 5 speed TD tuned 48.6 avg. SOLD
1999 beetle 5 speed whitbread built. SOLD
2002tdi is offline   Reply With Quote
Old September 28th, 2012, 06:04   #41
thundershorts
2002tdi, was your car part of the gp/software upgrade campaign?
Old September 28th, 2012, 06:17   #42
2002tdi
2002tdi's Avatar
yes it was, and that was done when i bought the car 9months ago. i bought the car drove it home and the next day it misfired like crazy when i started it. the dealer towed it in, replaced the EGR valve and did the glow pulg update. when i picked it up from the dealer the misfire was gone, but it still stumbles until its warmed up. its very odd...one day when i was sitting in the car texting a buddy i was watching the tach and it fluctuates until the moment it hits operating tempature and then its smooth as can be.
Old September 28th, 2012, 08:10   #43
lynnejohn
Fuel Economy: 46
I had mine checked for the glow plug update when I first got it and they said it had been done. 2002, how long does yours take to get to temp? I'm going to check over the weekend to see if my EGR goes to 100.6% at the same time or if it might be the temp(132 seconds or 34.2 degrees C.) I also wounder if their is anything else software wise that has an input to when the EGR changes. The dealership had mentioned some type of calibration or duty cycle setting on the EGR.
Old September 28th, 2012, 08:32   #44
thundershorts
the egr valve goes through its own gyration/calibration. Tuners often decrease the egr so that is definitely suspect. there were two gp campaigns, depends which one they said had been done. if the gp's are ngk, the latest are in it
Old September 28th, 2012, 08:49   #45
2002tdi
2002tdi's Avatar
forever, which every tdi i have ever owned does, if its warm out side...80 deg. about 15 minutes or 5 of highwayspeed driving. if i am just sitting there about 15.the moment it hits the half way point the idle goes completly smooth
2005 Passat TDI - Rough Idle Problem gtalum VW B5 Passat TDIs 31 August 1st, 2012 04:25
2005 passat TDI running rough captaindlowe TDI 101 9 October 19th, 2011 04:37
Rough idle when cold - 2005 Golf TDI Leebro61 TDI 101 9 July 18th, 2011 05:53
Low pwr, rough idle, sputtering in 2005 PD Zampano77 TDI 101 14 January 3rd, 2010 17:15
2.0 rough idle question POWERSTROKE VW MKIV-A4 TDIs (VE and PD) 5 August 28th, 2003 13:31
Page generated in 0.17637 seconds with 11 queries
[Output: 131.69 Kb. compressed to 110.61 Kb. by saving 21.08 Kb. (16.01%)]
