scrapn diesel
my second time on this great site! after having my car die and throw codes p1562, p1563 quanity upper and lower limit attained i bit the bullet and had the ip rebuilt and had injectors upgraded to 520's at dfi in oregon. at 60 k i did a t-belt service, ip pump at 70k, cleening the intake and new fuel filter, also new g plug harness which fixed my check light and car ran great, especially with the new 520's!! its been several months, but i did the install with vag-com, setting timing close to top of graph and checked something about the fuel, i cant exactly remember but since pump+inj's were done at the same time i presume pump was adj. for this. any ways new ip never fixed my long crank to start issue when warm (always starts when cold instantly) and car has funny shudder when coming to a stop with clutch in.since my batt is getting weak(original!)i replaced with a new one from vw. now at 77k my car is throwing codes p1562, sometimes p1563 and gplug light is flashing and car just dies at random. sometimes it restarts quickly, others i have to wait 10 mins or so. also when starting it revs by it self and comes back to idle or dies? but otherwise it seems to run ok, just cant trust it though. i will have vag com tool this week, and ive been reading this site for hours, but what do i want to set the quanity at and does a tuning box change what i need to set? what else do i need to set with v-com? has the shuddering prob been figured out or do i need ta make the switch?relay mod? this car is driving me nuts, any money i save on fuel just goes into repairs!!!!!!!! only your site helps me to afford this car.... thankyou- oh it does have a new 109 relay by the way..... oh, just found notes, set inj quanity at 3.0mg when i put ip pump in........
