03VWGolfTDIOwner
- Joined
- May 4, 2013
- Location
- Lower Mainland, BC, proud Canadian!
- TDI
- 03 VW 1.9 ALH Beetle Auto 192000km (April 2019 - RIP my '03 Golf)
So I have a MK4 VW Golf.
When I drive with the gas pedal depressed or when the car is coasting, at 1800 rpm only and only at 1800 rpm does the car start to make a vibration type of sound. Almost as if there is something touching but there isn't anything touching that could be found.
It can be recreated by simply depressing the pedal, when driving only, and slowly releasing it, you can then feel something as if there is either grinding or vibration. What could an RPM related vibration/resonance be related to? note: I have replaced the automatic tranny, mounts, front bushings.
