Moo Car
- Joined
- Mar 29, 2001
- Location
- Joliet, Il
1. This is what you are replacing.
2. Paint bottom of ball joint (will tell you why later).
3. Lube ball joint nut (very important to help get the top nut off later).
4. I use modified strut spring compressors to help with the job. You can do the job without the spring compressors but it’s a lot easier with it (especially on the driver side). Compressors cost me $10.
5. I use this same technique to remove the struts. It’s a lot easier to compress the spring first to remove the strut. But for the ball joint removal the compressor takes the spring load off the ball joint.
6. Remove the sway bar bolt.
7. Move the sway bar arm out of the way.
8. Loosen the top ball joint nut.
9. Loosen the top nut until the nut hits the steel half shaft hub. I learned this technique from a Fred’s member and will give him credit when I remember who it was.
10. Keep unscrewing the nut, putting pressure on the hub with the nut until it forces the shaft out of the wheel bearing housing. It doesn’t take a lot of pressure to pop it out.
11. Remove the three bolts that hold the lower ball joint.
12. This is where the jack should be (under the brake rotor) with a little pressure to support the axle.
13. At this point the ball joint will be loose so turning the top nut will also turn the stud that the nut is on. What I did was remove the rubber that is around the ball joint so that I could hold the stud with pliers and remove the nut (this is why you should spray the top LOCK NUT with oil). The stud under the rubber is full of grease and vise grips pliers or special pliers (see photo later) my not be enough to hold the stud. You may have to cut the nut off so be prepared.
14. Another shot of the pliers holding the stud to remove the nut.
15. Slide out the old ball joint.
16. Looks easy!
17. See how I had to remove the rubber from the old ball to hold the stud?
18. Slide in the new ball joint.
19. By hand, install the top nut on the new ball joint.
20. THIS IS WHY YOU PAINTED THE BOTTOM OF THE BALL JOINT. Using the paint marks, put the new ball joint bolts back in the same position that the old ball joint were. Your wheel alignment will now be back to where you started.
21. See how the bolts are back in the same spot that they were before?
22. Remove spring compressors.
23. Lift the control arm to press the new ball joint stud into the wheel bearing housing. Put enough up pressure on the control arm so that when you tighten the ball joint top nut it doesn’t spin.
24. Tighten ball joint top nut.
25. Reinstall sway bar bolt.
26. You’re done!
27. Photo of the tools used. Remember that you might need (I didn’t) something to cut the top ball joint nut or stud.
I’ve done both sides and the passenger side is easier (because of haft shaft length). So I would recommend that you start with that passenger side first. The job took me an hour and a half on the first one and one hour on the second. Yes I should have used new hardware, yes I am using a jack and jack stand to hold up the car and yes I should have used Amsoil yellow paint.
16. Looks easy!
26. You’re done!
