Old May 20th, 2019, 09:23   #1
PilotPat24
TDI(s): 2002 Golf
Default Increased Cranking Time When Starting
Hey Guys,
I have a 2014 JSW 6 Speed and recently the car cranks for about 4-5 seconds before starting for the first start in the morning. Any other start during the day after that starts normal. Any ideas on what I should be checking?
Thanks,
Pat
PilotPat24 is offline   Reply With Quote
Old May 21st, 2019, 00:05   #2
ksing44
That's a more recent development on my car too, but if I depress the accelerator 2x with the key on before cranking it starts immediately like it always did. I wondered if maybe it is something about the fix, but I don't think it started immediately after. I also have a CP3 fuel pump, but again the change didn't happen immediately after installation of the pump which was also before the fix.
My fix is 2 depressions of the accelerator just before the first start of the day. Then it fires right up! The rest of the day it starts immediately without anything special, even after sitting in the parking lot all day at work. For me, it's just a first start in the morning thing. Strange, but true!
2010 Golf TDI - (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP: 11/8/2016 @139,848 miles, The Fix: 9/27/17 @153,289 miles
Flickr slideshow
ksing44 is offline   Reply With Quote
Old May 21st, 2019, 19:03   #3
S1C EM
Originally Posted by PilotPat24 View Post
Hey Guys,
Thanks,
Pat
What is a normal interval? I noticed that my push button start is really a hold button for 2-3 second start. Looked in the manual and it just says “depress briefly.” That could mean anything. Is a 3 second push and hold longer than normal? I just figured it was a difference with diesel.
S1C EM is offline   Reply With Quote
Old May 22nd, 2019, 03:34   #4
Matt927
Matt927's Avatar
TDI(s): several
Noticed this as well. 2013 Golf TDI with fix.
First start of the day only.
Concerning the starter button, the logic with the older cars is you have to push and hold the button until the vehicle starts. I get in, push the button once, put my seat belt on and then push and hold until it starts.
Mk7 vehicles require one quick push of the button.
Matt927 is offline   Reply With Quote
Old May 22nd, 2019, 04:14   #5
S1C EM
So pushing and holding is normal on my model. Good deal.
Old May 22nd, 2019, 14:20   #6
slacker83
Mine does the exact same thing, but seems to be worse when the weather is colder. I was wondering if the fuel is bleeding back into the tank over night somehow.
slacker83 is offline   Reply With Quote
Old May 22nd, 2019, 18:10   #7
ShelbyRazorback
Mine seems to have started doing this as well. 2012 Golf 6MT. It doesn't seem to ALWAYS do this but sometimes does. I think it may have done it after work a couple times as well. If the engine is warm I haven't noticed it. I'll try the "pump twice".
ShelbyRazorback is offline   Reply With Quote
Old May 22nd, 2019, 18:25   #8
Ktmracer358
It happens to me in my 2012 golf 6mt as well. I tried the pump twice thing today after work and I fired right up. Might try to pretend pump twice just to see if it's just key on time.
Sent from my SM-G960U using Tapatalk
Ktmracer358 is offline   Reply With Quote
Old May 23rd, 2019, 19:08   #9
nucklehead
nucklehead's Avatar
Fuel Economy: 38
Hmm. My 2013 Golf starts right up with a couple of spins of the crank, just like my 2013 Jetta TDI did. The Golf is a post-fix TDI. I did have some warranty work done, the dealer had to replace the EGR plumbing, the DPF filter, and the cat converter. Also replaced at that time was the right drive axle and some other related parts due to a bent axle. How common is that? All at no cost to me, I just had to do was put up with driving their billboard car for 3 weeks.
I filled up today, got my best tank MPG so far, 39mpg, so that is looking better. Previous tanks were all right at 35-36mpg. The weather is much warmer now, 85* today. I don't drive the Golf to/from the golf course these days, it's Miata weather! So the Golf gets the longer trips only, which is no doubt better for the economy numbers. The Miata gets 27mpg whether I drive it nice or drive it hard. Unlike the Golf, the Miata gets up to temp within 3-5 miles, at least the coolant does, not sure about the oil, but it gets changed every spring.
Current Garage Queen - 1993 Miata Soft Top
Current Daily - 2013 Golf TDI/DSG
nucklehead is offline   Reply With Quote
Old May 29th, 2019, 17:20   #10
ShelbyRazorback
I tried the "pump twice" a few times. Mine still spins a few times before starting. It did it after work today. Doesn't do it all the time though. No apparent rhyme or reason to this that I can tell.
Old June 16th, 2019, 04:21   #11
prsa01
My 14 JSW 6m just started doing this last week. Mine had unknown age/miles fuel filter so changed that but it did not resolve the issue.
As with some others it is not all, but some, first starts of day. I am trying to keep track of whether the previous run was very short. Just moving the car or similar. I'll try the pedal trick and report back.
If anyone comes up with anything, please let us know.
14 JSW 6mt pano & backup cam
96 B4v eCodes
prsa01 is offline   Reply With Quote
Old June 16th, 2019, 08:48   #12
ksing44
I have to admit my pump twice routine for the first start of the day isn't successful anymore. It worked perfectly for quite a while. I'm experimenting now with pushing down the accelerator right before I begin to crank. As soon as it starts I release the accelerator. That seems to make a difference. It starts very quickly during what seems like the first cycle. I don't like to let it churn for 3 or 4 cycles, which is what happens if I don't touch the accelerator on that first start of the day.
As already discussed, it starts instantly anytime but that first time of the day. That's even true after 8-hours in the parking lot during the work day. It's just that first one in the morning for me. Just a note, I also have the CP3 pump and no auxiliary pump, but it seems that's not the issue because it's happening to many of you without the pump upgrade.
Flickr slideshow
Old June 16th, 2019, 19:16   #13
gorms400
Fuel Economy: 38-50
I hate comparing apples to Dodges, but my 07 5.9 Cummins does this whenever I dont run power service. Typically with those it is injector wear, but I have been dodging the injector replacement bullet for 4 years and 60k now, 225k miles total.
Our 2011 jsw seemed to fire off differently every time we started it. Have been running power service since we bought it (only 1500 miles) but it has improved. Not as many, if any, long crank times.
I am a firm believer in additives with common rail diesels, the injectors are working 3-4 times as hard IMHO.
11 Sportwagen 6spd 99k
01 Jetta TDI 5 spd, 265k mi
02 Jetta TDI - wrecked at 154k
98 Dodge/12V Cummins 5 spd, 300k
07 Dodge 5.9 Cummins 225k
gorms400 is offline   Reply With Quote
Old June 17th, 2019, 06:00   #14
dervdave
dervdave's Avatar
Long crank time can be an issue with the EA288 engine and there is a fix
https://www.youtube.com/watch?v=DXvHdmq0reA
dervdave is offline   Reply With Quote
Old June 17th, 2019, 08:18   #15
andreigbs
So would this be a warranty type issue? Or would you expect to have to pay to have it replaced?
Anyone have a part number?
2014 Jetta TDI // 28xxx miles // 39 MPG & 2014 GLK 250 // 98xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Cranking time BAZ3713 General VW Discussion 3 October 16th, 2017 12:21
Increased IQ, harder starting TDIPWR33 VW MKIII-A3/B4 TDIs 25 June 17th, 2014 09:12
Longer cranking to starting time. Knoxville TDI 101 23 February 13th, 2009 13:26
increased cranking required for startup ufoguy VW MKIV-A4 TDIs (VE and PD) 3 June 6th, 2004 09:18
Long Cranking Time When Starting Latenser VW MKIV-A4 TDIs (VE and PD) 9 June 20th, 2003 14:57
Page generated in 0.28903 seconds with 13 queries
[Output: 126.44 Kb. compressed to 105.17 Kb. by saving 21.27 Kb. (16.82%)]
