Old September 29th, 2014, 03:49   #1
xTDIx
Default Race Pipes, EGR Delete Kit's, Downpipes, Turbo;s ect
Our PayPal is tdiguygr@gmail.com details about order in the notes. Please verify that your shipping address is current.
Shipping is via USPS, FedEx or UPS we always use 2-3 day shipping options.
All Prices are CURRENT and include shipping to the States. Shipping to Canada ADD $20
ALH Race Pipe Aluminum W Boost Port $34.99
PD150/PD130 Race Pipe 57mm Aluminum w Boost Gauge Port $49.99
BEW/BHW EGR Delete Kit-$34.99 Includes everything to delete your EGR and EGR cooler, without large front plate to leave EGR intact $24.99
Dog Collar Fix for BEW Engine $19.99
BRM Race Pipe Kit $79.99
Stainless Steel Braided Turbo Feed Line for MK4, includes new crush washers for the fitting near the Oil Filter $39.99
ALH Delete Kit with Race Pipe-$34.99
Turbo Feed Junction Banjo VNT15 VNT17 VW P/N: 028145786 $24.99
CBEA CJAA Race Pipe EGR Delete $49.99
Oil Catch Can for ALH includes everything needed for install. This one does not have an internal baffle $39.99
2009+ TDI Downpipe DPF Delete $449
PD150 Intake with Race Pipe $260
PD150 Intake with Race Pipe DRIVERS SIDE Inlet $250
PD150 Intake ONLY $165
OEM Volkswagen .658 5th Gear Conversion $225
ALH/BEW 2.5" 304 Stainless downpipe $300 3 left we aren't doing another run of these.
VNT-17 Billet Compressor Wheel Turbo by Midwest Turbo and Performance.
GT22 360 deg Thrust upgrade
improved journal bearing design
Step gap turbine end piston ring
Billet compressor wheel
$594.99 We are offering $50 to anyone who purchases this and provides us with a review.
Garrett VNT-17 GT1749VB ALH-$724.99 BEW-$749.99 gone
Billet VNT-15 by Midwest Turbo and Performance $499, over 20PSI with the same warranty that the major turbo manufactures offer Gone
VNT 17 Adapter for ALH engines $65 Aluminum, very high quality.
We have a lot of other parts as well. email for questions.
We are opening up a 2,500 sq ft shop in August for local pickup, tuning, repairs ect.
xTDIx is offline   Reply With Quote
Old September 29th, 2014, 04:44   #2
oilhammer's Avatar
Fuel Economy: fantastic
Do you include a replacement heater hose then?
www.cardocautomotive.com
Old September 29th, 2014, 04:54   #3
xTDIx
No sir, I include a hose barb. We have been using this method for years at the shop. No problems.
Old September 29th, 2014, 04:56   #4
oilhammer's Avatar
OK, just curious, that's all. I've been looking for a stateside source for the BHW's non-cooled EGR heater hose and had not yet found one. I didn't think you did, since you lumped the BEW and BHW together, and they would obviously need a different hose.
I was able to get one for the ALH without any problem, but I think that hose is used on some of the gas engines here. BHW is a bit more tricky.
Old October 3rd, 2014, 15:37   #5
piran21
Can one still pass emissions with the race pipe? I'm not familiar what it does differently vs the EGR delete kit alone.
piran21 is offline   Reply With Quote
Old October 4th, 2014, 06:18   #6
xTDIx
That I am not sure of, I have not had the pleasure of living in a state that has had emissions tests.
Old October 6th, 2014, 03:49   #7
oilhammer's Avatar
Removal of emission components is against Federal law, not state.
Old October 6th, 2014, 06:27   #8
LNXGUY
LNXGUY's Avatar
Sure, as long as you've got a tune and the readiness monitors are set to 'ready'
I just had my '05 BEW pass, it's got zero emissions equipment on it (Although I only use it 'off-road')
Bill
LNXGUY is offline   Reply With Quote
Old October 7th, 2014, 02:53   #9
xTDIx
Copy that, I appreciate the correction.
Old October 7th, 2014, 15:23   #10
dowster
For those that don't know. What exactly is the MKIV trunk fix?
dowster is offline   Reply With Quote
Old October 8th, 2014, 03:15   #11
xTDIx
It's a fix for the broken plastic on the trunk release.
Last edited by xTDIx; March 28th, 2016 at 05:40. Reason: Img codes entered incorrectly
Old October 27th, 2014, 04:07   #12
xTDIx
ALH Race Pipe is back in stock.
Old October 27th, 2014, 21:22   #13
Jake_S
Jake_S's Avatar
Pm sent
Jake_S is offline   Reply With Quote
Old December 2nd, 2014, 06:02   #14
xTDIx
December Bump
Old December 19th, 2014, 20:56   #15
drywaller
TDI(s): VDUBS
Please excuse my ignorance. Can I completely remove the bew egr cooler and EVERYTHING associated with it when using your kit?
Is the barb fitting hardware store quality or better? I hardware store will it hold up to the high temps for years to come?
drywaller is offline   Reply With Quote
Don't I need 2 block off plates for my egr delete?? Somebody please help!!! ZTruitt7 TDI Power Enhancements 28 November 6th, 2013 04:18
Page generated in 0.18441 seconds with 13 queries
[Output: 124.99 Kb. compressed to 103.46 Kb. by saving 21.53 Kb. (17.22%)]
