shawna74
I hope someone can help i a 14 passat tdi 80k miles currently completely stock. I have what apears to be 2 issues with the car at this time but might be from the same issue. The car is experiencing low boost pressure and has only thrown a code twice i dont recall the exact code. All vacuum lines appear to be fine. I also am experiencing what sounds like water from behind the dashboard the coolant is normal no loss. And when i do hear this i do hear a slight high pitched whine from the engine and the car goes into limpmode for a short period of time. And will eventually kick in and boost back up. Im at a loss as i dont know where to start as there isn't any leaks in the cabin. Im fairly new to diesels. And i do have to mention i do have a partial clogged heater core. Not cold weather issues as im in south fla. Any help.would be greatly appreciated.
